[Z06] Valve Guide Material Preferences
Going to freshen up the heads on my street driven 30,000 mile 2007 Z06. Should I go with bronze guides (e.g. WCCH Stg 2 Pkg) or PM guides (e.g. AH Stg 4 Pkg)?
AHP is your best bet, I used them and my heads are there now.
Nothing but positive reviews.
Their powdered metal are there own recipe and better then wcch bronze
Received 1,041 Likes
2019 C6 of Year Finalist (performance mods)
Did AHP #4 since I kept the stock cam I used their PM guides. Had I gone with a hotter cam I think I would have upgraded like MTPZ06. I did go with the Ferrea exhaust valve. Valvetrain is very quiet now and I am happy.
OK. AHP it is. What do you guys think about the PAC 1515ML beehives -vs- the BT duals that AHP offers? From the BTR website: PSI 1515ML .650" Lift Beehive Springs. Designed for LS7 and other 1.950" installed height applications. 140 lbs @ 1.950", 405 lbs @ 1.300", Coil Bind 1.225", 1.290" OD, .630" ID I will also ask AHP about those...
With stock cam (and some aftermarket ones); the combined mass of using the combo of Ferrea f2042p hollow stem exhaust valves (that Kohle uses), 1511 beehives, plus Ti retainers, plus stock rockers has been tested/proven to be a good combo. That's precisely what I went with...along with Kohle's MS90 guides and a CHE trunion upgrade.
I have ahp heads non ported though with the stock cam and 1511s with tI retainers and on guides. Very happy if you actually do the math you lose about 1lb of valvetrain mass going with the 1511 and ti stuff. Even stick sorings with the 2024 valve which is all standard with ahp has been tested stable to 8k rpm
