C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Shifting question
Old 09-26-2016, 07:10 PM
JohnAlley
JohnAlley's Avatar
Default Shifting question
I have a 2011 Z06 Carbon Edition and it just started to "grind" a little bit when shifting from 2nd to 3rd. All other shifts are fine. Any suggestions as where to start looking for the problem?
Old 09-27-2016, 12:45 AM
SlowBusa08
SlowBusa08's Avatar
If you aren't able to do the work yourself, start looking for a shop. Sounds like it's time to start getting some trans work lined up.
How many miles are on it?
Old 09-27-2016, 07:41 AM
JohnAlley
JohnAlley's Avatar
Originally Posted by slowbusa08
if you aren't able to do the work yourself, start looking for a shop. Sounds like it's time to start getting some trans work lined up.
13,000
Old 09-27-2016, 12:20 PM
Too-Fast
Too-Fast's Avatar
I assume your in service date has passed and the 5 year 100k factory power train warranty is expired? If not, then a trip to a reputable Chevy dealer in your area would be my next step.
Old 09-28-2016, 01:07 AM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Sounds like a synchro...but check your clutch fluid first. Is the reservoir full? Secondly, is it full of clean fluid? If it's black, flush the fluid using the "ranger method" which you can search on here for the procedure. It'll take a few times, but the fluid will come clean. Test drive and see if there's an improvement. Whether or not this is the cure for your issue, this process should become part of your routine maintenance to keep the clutch hydraulics in good working order. I use Castrol LMA synthetic for my brake and clutch fluids.
Old 09-28-2016, 08:57 AM
z06clif
z06clif's Avatar
5 years and it should have the tranny fluid changed. I think its in the maint. schedule
Clif
Old 10-03-2016, 03:15 PM
JohnAlley
JohnAlley's Avatar
I have raced a ST2 Corvette in NASA for several years before retiring so the fluids was the first things I checked. All fluids were in good shape, most likely the stock transmission just did not like the extra 200 hp I was running through it. Heading to RPM transmission tomorrow for a Stage VI replacement transmission
Old 10-04-2016, 06:32 PM
MTPZ06
MTPZ06's Avatar
Ahh...good bit of information left out. Excellent choice on RPM!
To Shifting question
Quick Reply: [Z06] Shifting question
