C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] What brand oil/oil filter for aggressive driving?
Old 10-06-2016, 01:15 PM
ChrisM4
ChrisM4's Avatar
Default What brand oil/oil filter for aggressive driving?
Interested to know what grade/brand oil and oil filter people use
read several threads where people use Mobil 1 and/or AMSOIL for racing/aggressive driving but those threads are form 2011...
Which oil brand/viscosity is ideal? also which oil filter?
Old 10-06-2016, 01:25 PM
LMB-Z
LMB-Z's Avatar
The owners manual states Mobil 1. Any good brand of oil filter should suffice.
Old 10-06-2016, 01:44 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
I use Mobil1 M1-113 and K&N HP-1017 oil filters for ALL my driving in my Z06, whether I'm cruising along at 1500 RPM while on vacation or running around Talladega at WOT, shifting at 6,800 RPM at over 160 MPH.
I also run Mobil1 0-40 European spec oil ALL the time.
Old 10-06-2016, 02:11 PM
DaOtherOne
DaOtherOne's Avatar
Mobil 1 0-40 European spec during summer while doing track days. Mobil 1 5-30 during the winter.
Old 10-06-2016, 02:12 PM
ChrisM4
ChrisM4's Avatar
Anyone use Motul?
So would 0w40 european be better then 5w30? Los angeles doesnt get too cold
Old 10-06-2016, 03:53 PM
MTBSully
MTBSully's Avatar
I use 2 stroke oil.
Old 10-06-2016, 04:03 PM
C5 Hardtop
C5 Hardtop's Avatar
Wix or AC/Delco filters and any full synthetic that meets GM specs, preferably oil with a good looking picture, gives warm fuzzy feeling and meets GM specs.
Old 10-06-2016, 04:07 PM
C5 Hardtop
C5 Hardtop's Avatar
Originally Posted by ChrisM4
Anyone use Motul?
For high temp dot 4 brake fluid used for open-track, yup.
Old 10-06-2016, 10:56 PM
Dan_the_C5_Man
Dan_the_C5_Man's Avatar
I am currently using a 50/50 mix of M1 0w-40 and 15w-50 with an M1 oil filter, but there are other good filters as well (WIX, AC Delco, etc.)
Old 10-07-2016, 12:04 AM
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,509 Likes on 2,598 Posts
How do you use your car? For normal street use and oil temps below 265*F, M1 5W-30 is what GM recommends and is fine. If doing HPDE's where your oil temps could go over 265* (I saw 285* with stock LS7) M1 0W-40 is better for the high temps and fine for daily driving.
If your engine is modified, use what the engine builder recommends for your type of service.
The OEM GM filter is fine.
Old 10-07-2016, 12:44 AM
outhouse
outhouse's Avatar
M1 5W-30 and the best napa oil filter "platinum" Street only
Old 10-07-2016, 01:10 AM
Boba Fett
Boba Fett's Avatar
Same here. However I would go to 5W30 if I used in winter which I do not. The Viper gets Amsoil 0W40
Old 10-07-2016, 04:47 AM
Too-Fast
Too-Fast's Avatar
M1 0W-40 and Delco Filter all the time, mine see no winter driving.
Old 10-07-2016, 10:18 AM
dr_whigham
dr_whigham's Avatar
K&N HP-1017 and Gold Bottle Castrol Edge
Old 10-07-2016, 10:39 AM
Radical05
Radical05's Avatar
http://www.drivenracingoil.com/ full synthetic and AC Delco GM Filter
Old 10-09-2016, 09:25 PM
MickVette
MickVette's Avatar
St. Jude Donor '13
I'm getting ready to do something similar as Dan_the_C5_Man. Tomorrow, I'll be switching to Moblie 1 racing series half 0w-30 and half 0w-50 along with M1 filter. At the same time adding a -10AN MM catch can to minimize tha amount of oil ingestion to the intake so the increased zinc won't effect the high flow cats. My car typically sees 7300 rpms every time I drive it so I feel the racing series might be a good,way to go for me.
Old 10-09-2016, 11:16 PM
AzDave47
AzDave47's Avatar
Hopefully the oil is at least 160*F before you get into it hard and with an 09 it takes a while for the oil temp to get up there.
To What brand oil/oil filter for aggressive driving?
Old 10-10-2016, 12:51 AM
meanjoe
meanjoe's Avatar
Just wait a minute.......Here it comes....
Old 10-10-2016, 02:41 AM
bos3ayedzo6
bos3ayedzo6's Avatar
I use redline 5w-30 with zr1 oil filter
Old 10-10-2016, 06:57 AM
MickVette
MickVette's Avatar
St. Jude Donor '13
I noticed this car takes a long time for the oil to heat up, so I do have max rpm held back while the oil is still coming up to temp. I'll have to look and see what temperature the oil currently has to be to allow 7300. Just curious, how did you come up with 160? I was looking at the oil data trying to decide the right temperature to allow the engine to ring out but couldn't really find something that gave me a definite temperature to use.
Quick Reply: [Z06] What brand oil/oil filter for aggressive driving?
