[Z06] Broken electric fan housing. What keeps radiator upright
I own a 2007 Z06. My electric fan housing has broken on one side. Noticed that radiator will move back and forth now. Does the radiator support cover keep the the rubber feet in place at the top? It looks as though the fan is connected to radiator and AC condensor. Correct me if wrong or head me in the right direction. Will be removing (radiator) to replace fan and want to put it back together properly. Thanks for any help.........
All taken care of. Appreciate the info.
yes
It looks as though the fan is connected to radiator and AC condenser.
4 tabs on the radiator and the fan shroud slides down into the tabs
No not needed, get your hoses out of the way and it wiggles out with rad in
Thank you for your help. Tore into it yesterday and it is just as you mentioned. Will remove hoses and radiator support and lift out to repair.
