[Z06] Driver window issue
Driver window issue
Ok so when you open your door the window automatically lowers around 3/4 of an inch to properly seat back into the door seal when you close the door , my problem is that when I shut the door the window isn't going back up , it's only the driver door , the passenger door works perfectly , any ideas ?
It's called "indexing"...for some reason it happens to my car every few months. I'm going off the top of my head, but I think the steps are:
1. Start the car and close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and
release.
release.
