[Z06] LS7 Head Fix-Which one?
AHP's proprietary PM guides are as strong (on the hardness scale that I believe AHP provided,) but don't quite have as high of thermal conductivity as the MS90 guides. From what I'm gathering, AHP's PM guides are probably just fine (if not ideal) for a stock setup?
All the LS7 head issue news will undoubtedly hurt the resale value of our Z06's as they get up in mileage. One of the reasons I jumped in and replaced my heads on my low mileage Vette was to enhance its resale value as I have been looking to replace it with a 2010ish ZR1.
****, now I'm hearing the ZR1 LS9 is demonstrating similar premature valve guide wear issues. From what I am reading at least ZR1 reported problems have not yet resulted in destroyed motors. Here we go again?
GM's rumored DOHC engine is sounding better all the time.
ArmchairArchitect (08-30-2017)
Supporting Vendor
Received 1,012 Likes
I read where top NASCAR teams use MS90 guides in their engines and I like that, but my goals are not exactly the same as a NASCAR engine builder - I just want to ensure that my engine doesn't drop a valve and I'm more than satisified with the highest lift camshaft (.591/.591) on a production GM engine.
We enjoy answering questions about our heads so if you have any you can always give us a call:
310-326-2399
or shoot us an email:
HP@americanheritageperformance.com
http://www.americanheritageperformance.com/
Correct you cant go wrong with either our PM guides or our Moldstar90 guides, they are both top tier guides!!!
310-326-2399
310-326-2399
LSA, Ls3 and ls9 also have valve guide wear issues. They just don't run a thin wall 2 piece valve that likes to break apart as easy, even though it does happen. My friends bone stock zl1 camaro dropped an exhaust valve
Guides wear. They are a wear part, and to expect otherwise defies logic. Even fancy high dollar ones.
If staying stock, don't mess with roller tips or use heavier valves. Just get the guides worked and seats recut. The PSI spring is a much better spring than the OEM spring and a solid option with zero downside.
Supporting Vendor
The 1.7 ratio rocker on the LS9 is more forgiving to improper valve train geometry than the LS7's 1.8 ratio rockers.
jswilke (01-15-2017)
We do rework quite a few LSA and some LS9 Heads. We have seen some guide wear issues on the Zr1's but nothing like the Z06's.
LS7 valve fix
First post. Just bought a 07 z06 with 14500 miles. Want to get the valves issue resolved. No problems with the car right now. Just don't trust it. Called And spoke to Dave at WCCH. Told me they would install SS exhaust valves, new bronze guides, polish intake valves, and new springs. Does that sound about right. Car will never see any real rough use.
#33
I'm pleased with the work WCCH did on my build so far (4K miles - 1 yr, several performance events and run to 7300 rpm).
#35
I just completed my head swap earlier this week on my 2008 Z06. After numerous discussions with Kohle at AHP and Rich at Abel Chevrolet I went with this. My Z06 is otherwise bone stock and is not tracked. It does see occasional spirited driving at 6,500 RPM shift points max. For my needs I believe this combination will be fine and cost effective:
I'm in the middle of my head swap also using AHP package 4, but opted for porting and .020 milled head and shorter pushrods. just need to clean the decks and I hope my heads will be delivered soon. I also have B&B headers on the way.
