[Z06] Awesome injectors for 650rwhp n/a 93oct ?
I think i will need better then stock injectors aFter next round of mods...should be 650rwhp dynojet give or take....Any ground breaking awesome new injectors? Lol.....What lb should i think about 56lb and up to 80lb.?....zr1 injectors good? Ty
Lots of guys swear by ID stuff. They just came out with an injector that replaces like 3 or 4 other injectors in their line.
Im running some 60lb injectors from FIC that my tuner said were really easy to tune.
ID1050x for stock to 1000hp, ID1300x for 1000-1300hp, ID1700X for 1300+.
If you max out 1700x, start adding more 1700x. ID just posted a car with 16 ID 1700X this morning.
Injector Dynamics. 850's, 1000's, or the newest generation....1050X. I have wasted more f'ing money on other "cheap" injectors than I care to admit. Weird issues popped up with all of them, because the data they supply is crap. ID's and OEM are the only two options I will consider anymore.
Ty......so would zr1 be good? With 585rwhp and my stock 42lbs i was at like 85percent...so 700rwhp and down 60lb would be good? Trying not to spend the most money but not skimp....you dont get hp from a great injector correct?
i have LSA injectors on my car and I'm around 70% IDC @ 570 rwhp. I would do the ID 850's or the new 1050X.
We have had success with both Ford and ID injectors.
Current setup is using ID 1000s.
Here is a calculator for their injectors.
http://injectordynamics.com/injector-selector/
Ty for responses. .....gary you going to be out this year? Do you have a new goal? Tell rob to call me give him my number....i want to get a few things from him...ty
There are many guys running LSA injectors. They work great and don't pose tuning issues. Just be careful not to buy them from different batches. (Buy 3 from dealer x and 5 from dealer y) That is what I did and when I had them "balanced" I found that some were more than 7% off from each other. This isn't just stock injectors. I have had 2 sets of ID injectors that were around 5%. With 13 LSA injectors I was able to get within 2%.
Any goals for you? Or just trying to better your time? Just met fartpipe and picked up a bias ply drag pack and radial hoosiers.....Im not sure about 3.5 spacers on gto spares....Should i run these? Or just buy another rim? Ty
Bruce is a great guy. Extremely knowledgeable and helpful.
I never liked the spacers. Just ran the GTOs as is.
If the looks do not bother you, run those.
If you the looks do bother you, switch fronts .
Need some kind of spacer no? I tried just putting them on fronts and it looks like they will hit my z06 calipers.......maybe you thinking of ctsv spares? I dont care how they look ....
