[Z06] Possible Bad Lifter? Video inside
Does the roller still spin? I'm of the opinion the lifter probaby collapsed and just bounced on the lobe until it flat spotted the roller and started chewing it up. Just a theory.
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes
I figured as much... It's hard to tell which came first, the chicken or the egg. There's been quite a few "soft cams" and bad lifters alike. The second pic looks like defective cam hardening. Either way, you know what you've got to do. I'd probably go with the Caddi lifters.
MTPZ06 (04-17-2017)
Hard to say... The person I'd trust the most to answer this would be Michael D. This isn't a rampant problem so most would say "My cam is fine." Sad to say, it's probably the luck-o-the-draw more than anything. Comp Cams would probably be the first that I'd scratch off my go-to list.
It was the Texas Speed LS7R cam
meanjoe (04-18-2017)
That is a very aggressive cam for street useage, must be matched to well spec'd out and high quality springs. I would not be afraid of .655" lift, how is the car used will determine your cam choice, if you where happy with the LS7R then the BTR 4 will be fine for you. I used the Johnson Axle oil short travel (.058") lifters. Very nice lifters but I would probably go with the non-axle oil and .090" versions if I would do it again, was a major pita measuring for each pushrod length +/-.002".
#33
Your valve train was not happy.
That camshaft is way too f'ing big. Especially with an OE intake/TB and 7100 rev limit. Not sure who the hell talked you into that, but it wasn't a good choice. I just don't get this never ending desire to over cam this engine. Must be one of those "my dick is bigger than your dick" things.
Find a lifter with a .750" wheel. Axle oiling is not needed on a mild street engine. I don't think it's needed for any needle bearing roller. Bushed solids, sure you bet. Great idea. Needle bearing though??? Run good springs. PAC 12xx series.
#34
Yep, not surprised at all. LSL lobes...
You planning to replace your oil pump? It will definitely be scored. I'd also pull the dry sump tank, oil lines, and oil cooler, and flush them all out. Those metal fragments will be just about everywhere.
#35
I used to think the hoses to the tank could be cleaned and reused. I no longer hold that opinion. I spent about two hours cleaning mine out last week, and gave up. Ended up ordering a set. The oil pump pick up tube screen is also difficult to clean. It effectively trapped crap. The older plastic one is worse than the metal one..... Yah, I bought a new one of those bastards too..... Oh well, it was a good excuse to install the Aviaid tank insert, and Improved Racing pan baffle, seeing how I had both out of the car.
#36
#37
This is all terrible news. I don't even know what lsl lobes are.... Wtf this sucks
If it makes any difference the heads have pac 660 dual valve springs
#38
Here's a good post on Cam Lobes from MyLS1... https://www.corvetteforum.com/forums...post1591768836
I'd be looking at a cam from Cam Motion or EPS if I was shopping around.
#39
Michael - I agree. The oil cooler is basically impossible to flush. I felt like I was able to get my 09+ tank setup clean...but it took forever. I had to take every single piece/fitting out that I could.
#40
I had a shop spec me a cam. Comp with the most aggressive lobes for race only use. It was a smaller cam than I have now, a 228/232 but didn't drive nearly as nice, and ate itself within 800 miles.
Had pat G spec me a cam. Ordered another comp, 230/246 LXL/LXL and 20k+ miles later it is happy as can be in my motor.
As for why people throw these huge donkey dick cams in their cars, because of youtube and showing off at events. Got to have that mean sounding cam even if it drives like ***, is less reliable, less power where it counts, etc.
