[Z06] Feedback on this louvered hood
#41
The body shop already did a lot of that. With the first install (before any painting) and the front forward and flush with the front fascia (like the OEM hood was) and the hood latches at their lowest positions, the rear of the hood was ~ 1 1/2" above the fenders at the rear. Moving it back and up and doing some movement of the fenders got it to where it is now. The problem is the hood is too flat, it does not have the curvature of the OEM hood or the fenders. Discussions indicated this is usually due to the hood being removed from the mold too soon. Shipping costs made it unreasonable for me to return it for a (hopefully) better fitting unit. I use the car for performance events so it is not a show car and I can live with the fit.
DH
AzDave47 (07-18-2017)
#42
With the OEM hood running the Silver State Challenge at a steady 150 MPH for 90 miles, water would run 220* and the oil 240* in 5th gear at 4800 rpm steady.
CECoupe (07-27-2017)
#43
Fits fine with enough work/effort. Took me a solid 40+ hours of fitting it, and now I'm as happy as can be. Mine has zero of those issues now, but took a lot of work to get it there.
#44
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
They all need adjusting. My buddy's had the exact same initial fitment issues when we installed it. After hours and hours of adjustments it is now acceptable and nowhere near as bad as Dave's. If you send it back the next one will do the same thing. It needs more adjusting and I wouldn't accept those gaps, even on a track car. His works great now though and he runs cooler on the track.
#46
Received 1,679 Likes
What he said.... For that kind of money Dave that hood should fit like a glove..
I'll bet it works great though!
#47
They do fit like a glove, with enough work to fit them. You may need to slot or modifiy the hood hings, and latches to give more adjustment. Fenders and front bump may need adjusted. The 3 I've seen all fit great, but take a TON of time to get fitted correctly, just like any other hood.
#48
I'm still inclined to believe it can be adjusted better though. I wasn't blowing smoke when I said it's a time consuming PITA. And for what it’s worth, the fenders and bumper do not move much at all……. If your body shop told you they move and can be aligned, they are not being totally honest. I know this for certain, because I tried to move them.
#49
Mine was the same way, until I adjusted it.
#50
Bummer...... That's pretty f'ed up Dave. I'd tell LG to pound sand and get me another hood on their dime if it's that bad. 1.5" above the fenders is horrible
Unreal, I know if I tried to play around with it, the result would not be an improvement. My wife is smart, she calls the plumber to save money from calling the plumber to fix what I tried to fix. I know what I can work on well and when to have professionals do it right.
#51
My hood was identical to that when I first put it on. I adjusted it out. The factory adjustment may not be enough, and you may have to slot the mounts/etc but it will fit better. CPR has done those hoods several times, and I've seen them on cars at his shop, great fitment. I would find another body shop, and let them go at it.
#52
Supporting Vendor
the one my customer norm did, unreal i think you met him w/ the red grandsport i did forever ago. He did this hood and the fitment is flawless. Elite automotive finishes did it and warned him the time to get it perfect but he didn't mind.
AzDave47 (07-19-2017)
#53
You will see mine in October when the ARH 2" headers and ID 725s get installed.
#54
ID1050x are the smallest ID makes anymore FYI. No reason to run anything small than that. Could be hard to find a set of used or old 725s, nor would I want to unless the price is crazy low. The 1050s are a big step forward.
#55
Supporting Vendor
they still sell the 725 man, have a set brand new in the box. I could order a bunch more too
__________________
Cordes Performance Racing aka "CPR"
Owner of AZ's premier LSX/LTX motorsports shop
http://cordesperformanceracing.com/
www.facebook.com/cordesperformanceracing.com
joe@cordesperformanceracing.com
480-359-5914
480-359-5914
#57
Yah, looks like some places still have them, but they did stop making them awhile ago. I guess if there is still inventory cool, they are good injectors. IMO the 1050s are still the way to go because of the all fuel compatibility and better magnets, filters, etc.
#58
Since when did 40+ hours of fitting a premium body panel become acceptable? A little bit of fitting is expected, but if it takes 40 hours to get it right, the product is junk IMO.
#59
