[Z06] 2007 h/c/i z06 misfire
I have a cylinder 6 misfire and bank 1 lean code. Changed plugs, with ngk tr6's. Cylinder 6 plug was pretty black. Replaced all the plugs, check engine light went off after second start up. Day later it pops back on. The car sounds like its running fine and doesnt cut up or anything under WOT.
No engine noise, all the wires are good as well.
CEL CODES:
-P0171 System Too lean (Bank 1)
-P0306 Cylinder 6 Misfire Detected
The light originally came on while I was at the track idling while sitting in line.
Any suggestions? Appreciate the help in advance!
CEL CODES:
shewantsthezeee (03-27-2017)
Any news?
