[Z06] Optimal Cruising RPMs
I've got the Mild to Wild setup on mine and run it open most of the time. Nice to be able to tone it down when needed too.
I run in 4th around town and 5th up to 70 and then 6th for me.
I enjoy cruising with the flaps open at 4800 RPM in 5th. The only problem with the C6 is that cruise control only works properly up to 157 MPH. At 158 and above, if you try to put it on cruise control, it just keeps climbing.
CorsoZ06 (04-04-2017)
Received 1,679 Likes
I guess i'm old... 80mph, 6th gear, 1800ish RPM's....
Out here if I do more than 5 over I'm toast. Ohio state troopers love to write tickets.
Much of the west interstates are 75 limit with some 80 and one TX road at 85. CA is 70 though. More fun to run 90 miles on a closed two lane at 150, though.
My HCIE Fusion IIIs with flaps closed have light drone at 60-70, almost gone at 75 and entirely gone at 80, all in 6th. Open flaps around town is awesome!
We are also lucky enough to get crap 91 octane premium as the only gas in most places.
It's 70 on the turnpike here.
The gas I'll concede to you though, I love our 93 up here.
Some say the drone is intolerable...and while I can appreciate on a long haul this may be the case, it is a virtue of the LS7. In simple terms, the drone is the sound of a caged beast, YOUR caged beast...and with a stab of the throttle, that beast comes alive and roars for all to fear...music to my ears!!!!!
#33
The 1966 Grand Prix came from the factory with a big, round manifold pressure gauge mounted on the center console. In this case, the intent was to monitor fuel economy (9 mpg rather than 6 if you were leaning on it).
#34
Thank goodness for 93 octane here in TX...
I too am going with H/C/I with the BB Fusion 3's.... CANNOT WAIT to install... Currently bone stock... ZERO drone..
#35
Does this actually help? The gf is more accepting than I figured she might be but we all know she hates it deep down lol.
#38
It does cut it down, is it worth the $200....depends, i was being lazy and didnt want to pull all the carpet. I think if you pulled carpet and used sound deadening of your choice it would be as good or better
#39
If the BlockIt mat works enough to take at least 50% of the edge of the drone off I may consider the cost.
"Blah blah Corsa doesn't drone yada yada."
#40
I try and avoid low RPM as you are more likely to lug the motor and put undue load on the bearings. For this reason I always rev it out a little before switching gears. I never go past 4th gear unless on the freeway going over 65mph (used to do 157mph in 4th on track) and I never put it into 6th gear unless going over 80mph down hill or level. Doesn't help my gas mileage but my motor is happy (according to Blackstone) AND I don't deal with drone !!
DH
DH
