[Z06] Lets See your aftermarket valve covers
Like MTP said, will have coil to alt issues.
Just did a search for D3..... cant find it. Who sells, makes it?
EDIT. FOUND IT
I think you're actually asking about VCs with mounts integrated into them, but it's worth noting for anyone who may come across this thread in the future.
I hate that word - Corvette tax. It implies that we come up with a number that we need to stay in business and then tack on some arbitrary amount because we know people will pay it. We sell them for what we need to sell them for to stay in business while still casting them and machining them here in Michigan. We pay our employees to machine them so they can have a career and healthcare for their families. I could have them cast and machined over in China I suppose. Then lay off our CNC machine shop workers and they can collect unemployment and go on Obamacare. But, I'd rather not do that. If I could sell them for half the price I would, because I would sell 10 times as many. But, we do have a market for people who would like a quality part cast and machined in Michigan by American workers, so we continue to sell them.
/end rant
/end rant
I applaud you for both the response and the philosophy
#33
No, i will be putting mine in the fenders. It just seems that the stock valve covers are already close to the alternator and i know that many aftermarket ones are somewhat taller
#34
Well, then I think I helped answer your question. Some of them will require grinding of the alternator bracket. There is a rib built into it near where the coolant temp wire is attached to the bracket. That rib needs to be ground down and part of the corner of the ear where the alternator bolt goes through needs a little material removed.
MTBSully (04-06-2017)
#37
Agreed with MD. Function over form. Too many down sides and new potential failure mods just to look pretty.
The lower coil mounting boss on my holleys hit the alternator. Had to be ground down.
#39
I relocated my coils under my Haltech heat shield on each side of the air filter. Very easy to get to. To do this you will need to make your own plug wires. I made 4ft MSD wires and the OHM resistance was much less than the 1ft OEM wires.
#40
That's a great idea. Can you post a pic?
