C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
[Z06] Lets See your aftermarket valve covers
Old 05-05-2018, 08:41 AM
  #161
eb_rat_7
CF Senior Member
Originally Posted by MTBSully View Post
Thanks! Its -6 AN nylon. Available just about anywhere.
Thanks man. I can't make it this sunday because I have to help my old man get the boat ready to go in the water. Looks like it might rain? Do they do it every sunday? Whats the schedule like? I'll try to make one sooner than later
herb chambers is once a month. It's more of a hike for you but larz anderson cars and coffee is spectacular when the weather is nice. This month is on the 19th.
eb_rat_7 is offline
Old 05-20-2018, 11:47 AM
  #162
Schred86
CF Senior Member
Schred86's Avatar
Just finished up passenger side. Holley tall in satin black. Re ran intake line to air filter with 3/8 nylon fuel line hose back to dry sump. Used 3/8 regular fuel line for breathers on valve covers. I also tucked the evap lines under throttle body(PITA). Used 3/8 nylon for gas tank evap and 3/8 regular for intake mani. Worst part is that i go to do the drivers side and the coil bracket doesn’t work with the coil pack. I contacted holley to see what they say, if nothing else i will have to grind away some so that the coil fits. Anyone else have that issue?
Still going to add some mesh loom for coil wires.
Schred86 is offline
Old 06-03-2018, 07:08 PM
  #163
Ronnie_C
Junior Member
Ronnie_C's Avatar
Just finished up my coil pack relocation and new valve covers, came out awesome!! Thanks for the inspiration!! Enjoy the pics..
Ronnie_C is offline
Old 06-03-2018, 07:20 PM
  #164
jayyyw
CF Senior Member
Those katech covers are so nice.
jayyyw is offline
Old 09-20-2018, 01:50 AM
  #165
Josh B.
CF Senior Member
Josh B.'s Avatar
Well after saying all winter "I have all winter to do it" I realized its mid april and I should get going on this project. Luckily new england has had a terrible spring so far so I havent missed any real driving time.
All the goodies:
Fender removed. pretty straight forward
2nd attempt on mounting the coil bracket. 1st one interfered with the fender tab that protrudes near that area. Had to move it up. Coil wiring will come through top hole, plug wires will go through bottom hole.
have to say im a little disappointed in the michigan motorsports coil relocation brackets. The spacers included are not quite long enough and when all 4 are bolted to the bracket, they can shake around like a rattle. Going to have to find a way to correct that.
Made one wire and should finish up the drivers side tonight. I noticed that my coil side terminals are a little different than the MSD wires i took off. The terminal on the original wires appears to have a black "guide" around it, whereas the ends that i bought from MSD dont. Any ideas? The boots say LS1 and I know they have the same coils as LS7 so im not sure if it matters or not.
Also will be ordering some fittings and line for my valve covers/PCV project and some wire sheathing to clean up the engine bay
Great pictures for the coil relocation. I saved them as a reference for my own project, doing this soon.
Josh B. is offline
The following 2 users liked this post by Josh B.:
jayyyw (09-23-2018), MTBSully (09-20-2018)
Old 09-20-2018, 01:52 AM
  #166
Josh B.
CF Senior Member
Josh B.'s Avatar
I had some in 2015. With powdercoating and the relocator brackets they were stupid expensive, and heavy.
Josh B. is offline
jayyyw (09-23-2018)
Old 09-23-2018, 09:06 AM
  #167
jayyyw
CF Senior Member
*gasp*
jayyyw is offline
Old 09-25-2018, 11:00 AM
  #168
RobGOV-DCZ
CF Senior Member
Visner Engine Development billet valve coversName:  photo491.jpg
RobGOV-DCZ is offline
Old 02-17-2019, 05:03 PM
  #169
Old Man in a C
CF Senior Member
Old Man in a C's Avatar
Call me old... I am, but I don't understand why we would want to hide this LS technology. Maybe we can hide the fuel injection under a dummy 4 barrel. How about a fake dual point dizzy too? All kinds of possibilities here. I'm thinking some stamped steel wheel covers would be the bomb. Crazy
Old Man in a C is offline
Old 02-17-2019, 06:08 PM
  #170
NVNO1
CF Senior Member
NVNO1's Avatar
Katech covers
NVNO1 is offline
Old 02-17-2019, 09:57 PM
  #171
Hib Halverson
CF Senior Member
Put these on a couple weeks ago.
Hib Halverson is offline
Old 02-18-2019, 09:20 AM
  #172
0H8Z06
CF Senior Member
0H8Z06's Avatar
How bout we simply call you "Negative Nellie"... Not one negative post in the entire thread then you come along. Thanks Debbie downer...
0H8Z06 is offline
Old 02-18-2019, 10:32 AM
  #173
FNBADAZ06
CF Senior Member
FNBADAZ06's Avatar
I'm starting to think about this coil relocation idea into the fenders. Has anyone that has done this mod found any negatives after performing this ?
FNBADAZ06 is offline
Old 02-18-2019, 10:38 AM
  #174
RobGOV-DCZ
CF Senior Member
None so far.
FNBADAZ06 (02-18-2019)
Old 02-18-2019, 11:07 AM
  #175
MTBSully
CF Senior Member
MTBSully's Avatar
because its ugly. Just like you.
MTBSully is offline
Old 02-18-2019, 12:06 PM
  #176
Unreal
CF Senior Member
Unreal's Avatar
Received 1,413 Likes on 1,203 Posts
Just the 20 minutes or less to pull a fender if you need to swap a wire.
Unreal is offline
Old 02-18-2019, 03:07 PM
  #177
Old Man in a C
CF Senior Member
I stand corrected, now shut the **** up.
Old 02-18-2019, 03:09 PM
  #178
RobGOV-DCZ
CF Senior Member
Old 02-18-2019, 07:01 PM
  #179
Old Man in a C
CF Senior Member
Aw c'mon
Old 02-19-2019, 09:33 AM
  #180
0H8Z06
CF Senior Member
0H8Z06's Avatar
Nice.. A "tough" old man at that!
Keep typing Old Man "C"ock in your mouth...
Tell you what, take your Bitch *** over into the corner until you can be nice. THEN and only THEN can you come back out and play.
0H8Z06 is offline
Quick Reply: [Z06] Lets See your aftermarket valve covers
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
