[Z06] Ls7 Engine
Ls7 Engine
Im going for a high mileage Ls7 Zo6, it has some work done but would kind of work would need to be done in order to keep it strong, as ive heard they are ticking time bombs and what not, what would be the first thing to do engine wise as I got it
get the heads done and make sure it's been taken care of. They are not ticking time bombs at all. Just like any other ls they will run a long long time if taken care of.... and the heads are fixed.
What kind of work? If the bottom end is in good shape, do a top end refresh. R&R the heads (guides, springs, etc), at a minimum inspect the cam lobes for excessive wear, new lifters and trays, new push rods.
DH
The following 2 users liked this post by Dirty Howie:
67 327/400 (04-07-2017),
patron1992 (04-07-2017)
Max G’s
ticking time bomb?
Far from that.
Like said above, R&R the heads, guides, fresh VJ, deck .020, Straub bushing kit, new seals, replace TC, call it the day.
Far from that.
Like the previous two said.. check the rocker trunnions as well. Here is my thread https://www.corvetteforum.com/forums...post1594486920 where I just replaced my comp Trunions with the Straub kit. Make sure that area is good to go as well. I too am new to this platform(owned my C6Z for month and a half) and I have spent money on things I wasn't expecting. I am sure now it's the nature of the beast. Get heads fixed first thing if not already done. Good Luck
