[Z06] Repairs to Z06 aluminum frame
Hit in the right rear quarter panel at 15 mph and slightly bent the frame. I am being told this is unrepairable and I will have to total a perfect car! Can this be fixed? Any experience fixing bent frames?
If they're saying this because the frame cant be repaired, that's untrue...it just may be cost prohibitive for your vehicle. I see you're in Fallbrook...I highly recommend Phil Thearle's Autowerks in Santee...the place is so clean you could eat off the floors, and they do a ton of high end cars. I think they are the only Jag/Landrover Certified body shop in the county for aluminum work. Maybe get an opinion from them...I trust what Phil says.
Aluminum doesn't bend like steel.
You can take a steel frame and bend it back pretty easily. Aluminum will tend to crack more often than steel when you bend it. You CAN heat it up and bend it, but that's a very complicated process.
Most places just don't do aluminum frame work.
Received 8,927 Likes
If it is the frame rail visible in the wheel well the manual says to purchase a Service Frame Rail and use it to replace the damaged section of the frame.
Bill
How do you know the frame was bent? Where is it bent? What other damage was done? Who is telling you the damage is not repairable?
Bill
Bill
Received 2,061 Likes
Worth checking this.
http://www.ebay.com/itm/06-13-Chevro...966?rmvSB=true
Up for auction is an aluminum frame rails from a 2006 Chevrolet Corvette Z06. These rear rails will come as pictured. The rear rails will be a direct fit for the 2006-2013 Chevrolet C5 Corvette hardtop Z06 models. It may work with other models but please check with your dealer on custom applications. Also please ask any and all questions before bidding or buying.
An excellent find if only typo, a solution for OP @ <$1K.
Buyer to pay $250.00 - $650.00 shipping to the lower 48 states. These will need to be cut to ship.
Gotta be me, surely assembly could be palletized & shipped freight.
The reason rear frame work is problematic is because it requires specialized skills and equipment just to work with aluminum. That commands a higher $ per hr rate. Then when working working on the rear frame rails the whole tub assembly must be removed which again is time consuming. You can't splice new rails in with the tub in place because you would be unable to weld all the way around the rail. Not to mention the tub is glued to the rail. When you total up the labor and parts for a rear frame repair on any C6 vette and factor in the insurance co's formula, it's pretty easy to call something like that a total.
If the frame rail moved 3/8's of a inch then I suspect the glued joint at the tub is broken OR the glued joint held and the tub is broken. Pull up the carpet and check the tub for damage inside the car. Post some pictures of the damage please.
