[Z06] Purchased "fixed" heads from vendor, still dropped a valve <500 miles
So the following specs are for the heads/cam I had installed. Going to try and contact the vendor when they open up in a couple hours.
1.61" Hollow-Stem Exhaust Valve
2.200" Titanium Intake Valve
.660 Spring Kit w/ Titanium retainers
7.800 Chromoly LS7 Pushrods, 3/8 Diameter with 5/16 Ball Ends
Cam- 234/246 .635/.635 (w1.8 rockers) 115+3 LSA
This was all fully assembled prior to arriving to me.
Intakes were OE Ti. No lash caps present on any of the other intact Ti valves. I have a picture of the heads prior to installation and they don't appear to have lash caps. Should the installer of the new heads have swapped lash caps with my stock heads? I'm a bit ignorant when it comes to this unfortunately.
If you got the R&R'd heads from AHP, they note in the packaging in very large and bold letters that lash caps must be used and the installer will not have an excuse for "not knowing" about them.
Here is another thread where the same thing happened...missing lash caps, and a dropped valve. Most mechanics that don't specifically have LS7 experience, wouldn't know anything about the caps being required. Unfortunately, sometimes the simplest mistakes are the most expensive.
https://www.corvetteforum.com/forums...-hills-sd.html
Really unfortunate position that you are in. Certainly the lack of lash caps on Ti valves would be an issue.
Sounds like you are going to need a whole new bottom end, and you might end up needing an entire new engine. $8.5k sounds like a good deal for a rebuilt LS7 if you could perhaps get some paperwork on it. Would have to pick it up locally, in NH.
http://www.ebay.com/itm/LS7-7-0L-V8-...RYZU5p&vxp=mtr
IF these are OEM inakes AND you know what a lash cap is AND there isn't one on every single intake valve, someone (the installer, NOT the head re-work vendor) owes you a motor, peroid-end.
My advice, DO NOT open the other valve cover, or if you do, video tape the process (not pictures - you need proof that you didn't take them off yourself) - no vendor, no matter how large, wants to eat 10K in parts and hours of free labor, not to mention the credibility hit they will take.
#33
I think the mechanic who didn't install the lash caps has some liability here. I'm sorry to see this happen to you. You may want to contact an attorney before doing anything else.
#34
ASE= Ask Someone Else
seriously some of the worse mechanics I've ever met are "certified"
not taking anything away away from the OP but he said he wasn't that far in depth with these things so are we sure the lash caps are missing? It certainly would make sense. Even a worse case scenario of bad stock heads wouldn't cause failure in 500 miles, on the intake valves no less.... pretty evident it seems there was an install error or faulty part here somewhere rather than the typical guide issue
#35
#36
that spring kit and cam lift sounds like Texas Speed. am i right?
and to answer your question, no the vendor is rarely ever liable.
they have no control over weather you sprayed 400 hp of nitrous threw it, or down shifted to 1st gear at 80mph etc. even if you didnt.
#37
Location: Virginia Beach, VA & Port Charlotte, FL (snowbird)
Received 1,095 Likes
Edit: It sure appears to be an intake though, especially in light of it not having lash caps. It would probably take about 500 miles for the rocker to eat through the titanium valve tip, enough to wear the valve tip down to the valve lock/keeper groove. The locks would then pop out and the valve would then drop. The rest of the intakes probably aren't far away from dropping.
#39
I had a local company build my car and I now want to go check my valves for lash caps, because I certainly haven't looked since my heads were rebuilt and installed.
#40
IF, and its a big IF, this is a matter of not re-installing the lash caps, i.e. an installer error, the brand of head has zero impact on the outcome.
