[Z06] Heads, how important is it to fix?
When searching for a z06 to buy its not easy to find them with the heada addressed. Is this something that has to be done, whether I find one fixed or so it myself? Is this something that generally happens early on so if one has say 40k miles without issue is it still a worry?
I have seen them fail at 14K....got mine fixed at 85K...there is no specific mileage....they fail when they fail......you may never have an issue
I had 2 guides that were out of spec bad enough to be concerning and others borderline...
a few thousand vs $20K....the decision was simple for me
How comfortable are you with a $15K gamble?
My '09 C6Z had 14/16 guides beyond GM service limits with only 15K easy street miles. How long could I have gone on like that? Who knows, who cares...I fixed the problem and I sleep good now.
Cruising is the passion!
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
11BtoPA (07-23-2020)
For me, peace of mind is priceless. Maybe my heads would have lasted 100,000 miles, maybe 10,000 miles. Do you want to stress about it every single day? I didn't. So I gave my money to AHP to have them updated. Are they permanently fixed? I don't think anyone can prove that. But they were updated with aftermarket parts that do not have the machining error that the stock head components (valve guides) had. So, I sleep at night, I drive my car hard, and I don't stress about it anymore.
I purchased mine just a couple of months ago with 23K on the ODO, while driving was a blast, it takes the fun out of it thinking about the heads. I suppose I could have just done the wiggle test, but decided just to get them replaced. I'm currently in the middle of doing the head fix myself, just need to clean the decks. Ordered package 4 from AHP, ported and milled .020 which should be in any day now.
It's either that or know going-in there's a risk to the tune of $15-20K.
This is nothing to take lightly, if mine hadn't been covered by an EW over my 9 years of ownership to this day?
Heads would've been rebuilt, long ago.
Once LS7 heads are addressed, one way or the other, Z06 ownership's pretty bulletproof. Like tires, brakes, insurance add heads to the cost of Z06 ownership. Small price for such a fabulous car.
2009 Z06 26,871 not tracked on a GMPP.
It's in the shop getting New heads and valves,cam, lifters, along with all the labor and parts needed for a thorough cleanup/detailed engine/oil system.
Probably about 8 grand total so far. My total cost is the $200.00 deduct.
I will not drive it without the heads fixed or a GMEPP on it.
Edit: my story if you didn't see it.https://www.corvetteforum.com/forums...-chirping.html
Landru (05-11-2017)
I would get it done to be on the safe side. My car is a 2006 and had 2,100 miles when I purchased it last year and I had it done. My shop recommended it no matter the mileage. You can do it in conjunction with some performance upgrades. For example, I went with Stage 2 ported heads and upped the compression to 11.5 to 1 vs stock 11 to 1. It's a no brainer if doing other mods. Even if you plan to keep it stock, it should be done as a precautionary measure. From what they told me, you can drop a valve at any mileage at any time. It's a defect in the factory heads/valve guides, but GM is no going to do anything about it.
you can go by what a few say that is complete opposite of this forum. case in mind, my car. 54,000 miles on and hanven't touched the heads. Some have said that the majority of failures happen between 15,000-30,000 miles or something. once cars make it over 50k miles they are known to be the ones that were ok. This is just a theory some have. there were some that the guide clearances were perfect and don't wear out. not 100% were defective.
to be safe, send them to American Heritage and get it done. I will eventually when I'm ready to do a cam and intake manifold. do it all at once.
