[Z06] what are you doing to keep brake dust off your wheels?
I have an 07 Z and the dealer put 4 factory rotors and full set of pads on the car before I bought it. All GM parts. I noticed the brake dust is horrible. Worst brake dust car I've ever owned. Is there a type of wax or coating I can put on my wheels after washing them to help? Do you guys literally wax the wheels with wax for the paint? What should I use for best results after I get them all washed and clean?
I have an 07 Z and the dealer put 4 factory rotors and full set of pads on the car before I bought it. All GM parts. I noticed the brake dust is horrible. Worst brake dust car I've ever owned. Is there a type of wax or coating I can put on my wheels after washing them to help? Do you guys literally wax the wheels with wax for the paint? What shoudl I use for best results after I get them all washed and clean?
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
New pads. Try Carbotech 1521 or Powerstop Z26. Both are low-dust.
On my C7Z I also applied Gtechniq C5 Wheel Armor. It does help to repel the dust and is far easier to remove.
Another option I used to use is Rejex. It is a synthetic wax/sealant and works well on wheels, and the car for that matter. Go with two coats.
armor all brake dust repellent.
https://www.youtube.com/watch?v=mJB1WocgdKo skip to 3 min to see results. Not my video btw.
I changed the pads to Hawk Ceramics. Very little dust now. Before I had to clean the wheels every time I drove it.
Supporting Vendor
St. Jude Donor '11,'13
You can switch your pads to the Carbotech 1521 if you prefer not to clean your wheels every day. The 1521 should cut your brake dust a significant amount and is a 100% non-corrosive dust will not harm your wheels or paint. The 1521 is a ceramic BASED compound that still offers very effective braking power. Price is below if interested give me a call at 216-780-8825 to order or go direct to website http://ampdautosport.com/brake-pads/corvette/ and use promo code z28 when checking out for forum discount.
F: 1 piece CT1185S
R: 1 piece CT1185R-S
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
F: 1 piece CT1185S
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
If only street driven then ceramic pads - I decided Powerstop Z26, but have not installed yet. There are several posts sharing results from dust level testing and feedback on the C7 forum.
If using for HPDE/track - then will just have to clean often.
I just ignore it. Then again I have black wheels. Carbotech XP8s that dust like crazy. Every time I wash the wheels I'm amazed at the dust that comes off.
Lots of good suggestions. The armor all spray stuff works well. A low dust pad like 1521s work well too.
1) I use my Master Blaster blower to get any loose dust off.
2) I use normal car shampoo from Adams to lightly clean off the wheels.
3) Dry thoroughly.
4) If I'm feeling motivated I'll add some Rejex. Otherwise I stop after #3.
I'm using Powerstop Z26 and never need to use a towel or brush to clean my front wheels. My rear wheels are still in front of OEM pads, so they need regular maintenance.
