[Z06] OMFG! My Z06 has...electrical parasites!
Pro Mechanic
Pro Mechanic
Been having trouble with the battery not holding a charge. After replacing the five year old battery, the problem persists.
After making sure the new battery was fully charged, I began a parasitic loss test. Once modules go to "sleep", draw is 600 milliamps which is way high. It should be below 25 milliamps.
Anyone here have experience with a parasitic loss like that.
If so, where did you find the problem?
After making sure the new battery was fully charged, I began a parasitic loss test. Once modules go to "sleep", draw is 600 milliamps which is way high. It should be down around 40-50 milliamps.
Pro Mechanic
Pro Mechanic
I posted because I was interested to know where people with the same/similar problem found a solution, like...is there a module which has a common failure mode that causes high parasitic loss when all the other modules are dormant?
Some others to look at https://www.corvetteforum.com/forums...in-help-3.html
https://www.corvetteforum.com/forums...problem-4.html
2008 Battery Issue
I am having the same issue. I get in the car, but when I hit the switch I get a click. Car does not start. By holding down the button the dash does light up and I see the battery is at about 8 volts. Hence not enough power to start.
The engine light does light up. After removing the ground from the battery and waiting 5 minutes, the car starts. I turn it off and it starts. Think problem solved. Gauge shows battery at 14.7 volts.
The next day car does not start. I try the same thing and now the car does not start. I get that click and the engine light. Dash is dark.
What gives. Getting a new battery tomorrow.
Pro Mechanic
Pro Mechanic
It could be OnStarhttps://www.corvetteforum.com/forums...ead-again.html
Pro Mechanic
Pro Mechanic
I found the draw. It was a cell phone related accessory. Made a change and problem solved.
Thanks for all the suggestions, guys!
I had an issue with the PAC iPod interface. Don't know what happened, but it would kill the battery in just a few hours.
EDIT: Nvm, you just posted your issue.
Hi Hib....I had this for months and finely took my car to my dealer who has a Corvette specialist.....It took hem about 5 minutes to find out the problem......The Corvette sensors are so sensitive and they look for anything about the same frequency there on and will not let the car "sleep"......My no no was an Escort Radar detector with GPS...as it would look for GPS position updates, it would wake the car up....over and over....Even with the detector off.....Anything like this,,(cell phone, non-OEM nave system,etc.) will not let the car go to sleep mode. I now unplug the detector....all good....
Pro Mechanic
Pro Mechanic
Hib if you see this link me to your pup cat thread pls.
