[Z06] Stuck lifter... Now the upgraded 7.7
That set up should make over 600 on pump gas, I just finished my 429 with Reher Morrison doing the work forged piston's Matt finished my tune up 2 weeks ago very pleased car makes more power from start but chokes up with 13/4 headers anything over 550 u need a bigger header, I'm using the lgs time to make up the power up top. Low end torque was 515....good luck 21 century dis my previous cam set up.
Former Vendor
We did not get to see the lifters or the cam from the damage done, but from the parts found in the oil pan and pickup, it had a locked up axle/wheel to the lifter and lifter let go. There are bits and pieces of the roller bearings from the lifter axle in the pan long with pieces of the roller on the lifter. Few nice small pieces of the engine block as well.
Can hardly wait to see the results.
Here are some more pictures of the bottom being getting built. The guys at HPR are over at the shop staying late to get the engine built in time for me to make it to Optima Pikes Peak. Thanks guys!
Former Vendor
#34
Car still was running strong comp says it wasn't there cam... I def keep oil plenty and never low lifters were originals 66k I did the swap 86k this is what I pulled out.. I can understand 1 2 lifters failing or pitting but all lol really...
#36
08z I have a new slave for your clutch I see the green slave looks worn out If you need it its new in box...
#37
Looks like your making one heck of a mill over there
What's the manufacturer of the crank, rods, and pistons?
What type of valvetrain will you be running?
#38
Former Vendor
- Darton sleeved 5.3L Gen IV block
- K1 forged, long post, 4.25" stroke crankshaft
- HPR spec 6.125" forged H beam rods by Wiseco
- HPR designed forged pistons by Wiseco
- HPR ring pack
- HPR custom ground cam 254/260 .655/.655
- HPR double taper pushrods
- Morel 5206 link bar lifters with .750 wheels
- Cometic head gaskets
- WCCH ported LS7 heads (customer supplied)
- LS7 rocker arms
- Katech oil pump
That is what we are assembling here, 21st Century Muscle Cars and the customer are taking care of the rest.
#40
Former Vendor
Going on a road race engine for realiblity when the customer isn't using a bottomless bank account you must pick your items wisely for both power and long lasting performance.
The following 4 users liked this post by HP RESEARCH:
