DSX Tuning Flex Fuel Kits - easiest install there is
Former Vendor
Disclaimer: **pinning the ECM is still an unavoidable evil!**
I had some custom fittings made for me (right here in the USA) to facilitate even easier installation of the flex fuel kits. They don't require any wrenches to install, and the fuel line disconnect tool that's needed to take apart the stock line is included with each kit. Check them out! I had some female to female push connect fittings made as well that turned out pretty damn slick.
C6 Non-ZR1 Flex Fuel Kit - $300
C6 ZR1 Flex Fuel Kit - $300
Former Vendor
If my car has aftermarket rails and customer fuel lines, what is the best way to add this to my setup without having it look out of place? Pictures for example of how the setup is configured.
Former Vendor
I offer a sensor with a custom harness which is probably best. It'll allow you to put it wherever you want.
Former Vendor
I bought your kit for my 07 but haven't installed it yet.
What do you mean by "
I wasn't aware I needed to do this?
