Why combine Z06 and ZR1 ?
I must have missed it but what was the motivation for combining the Z06 and ZR1 threads ? Are you going to do this with the C7 sections when the ZR1 is here ? I find it very taxing to scroll through the topics and then have to check if its related to Z06 or ZR1.
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Very taxing? To scroll through some extra threads? Most of which have [ZR1] or [Z06] neatly labeled in front of them? Are you serious with this?
Anyhow, the ZR1 forum had slowed down considerably and was riddled with mostly vendor posts. So they combined the Z06 and ZR1 forums to keep things active. A few of the ZR1 guys don't like it as they enjoyed the exclusivity. But not a big deal. They did screw up the search function though for us Z06 guys.
Sorry for having an opinion. Maybe you would like it if they also added C6 General and C6 Performance to the combination since you don't mind checking which car it applies to? Your explanation is also weak. The effort to move everything was not worth it and they should have left it alone to be consistent with other sections. Note that C5 still has C5 General and C5 Z06 separated.
It isn't "my" explanation. It is the forum owners and administrators explanation. I don't run this forum. Do you understand this simple thing?
And if one section slowed down to a literal crawl and was filled with nothing but vendor posts then yes I would expect it to be consolidated. Simple stuff for simple minds to comprehend.
Furthermore, your alternative examples are straw man arguments. They didn't combine the C6 General and C6 Tech/Performance. So why are you using this analogy? And the C5 did not have a ZR1 forum to slow down. The C5 General and C5Z forums are still busy as they made many of those cars. Again, a straw man logical fallacy.
Fact is that they combined the C6 ZR1 and C6Z06 forums. If you don't like it then there is a "Feedback" section to air your complaint. You understand?
Did you skip your meds today ? You sound like a real piece of work with all your insults when someone posts a simple question. Anger management classes are in your future. Maybe you should read the rules about being on this forum and how to treat people nicely. Simple stuff for simple minds.
I'm actually in a pretty good mood today. It finally didn't rain a monsoon so both Vettes are out of the stable for some shake down runs before this weekend's track events.
Received 1,303 Likes
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
https://www.corvetteforum.com/forums...post1594926409
Will there be a similar merger in C7 when a ZR1 is produced? The crystal ball isn't clear on that at the moment. We'll deal with any issues in other sections as they arise.
Meanwhile, I've closed this thread. We are best able to address complaints, questions and suggestions via PMs:
https://www.corvetteforum.com/forums...questions.html
The thread also has degenerated into a pissin' match. Some of you could benefit from a review of the rules regarding hostile posting/personal attacks:
https://www.corvetteforum.com/forums...rd-others.html
