C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Needle bearings found on drain plug
Old 07-26-2017, 02:41 PM
Tennispro1986
Tennispro1986's Avatar
Default Needle bearings found on drain plug
So I have my 06 in for the heads to be fixed and the said they found a few needle bearings on the drain plug. They said just needed to replace the rockers and all would be good. Should I be worried that their are other needle bearings floating around in my engine or is it fine to just change the rockers and that takes care of it?
Old 07-26-2017, 02:50 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Have they told you which rocker arm came apart, or if there were more than one that came apart?
Old 07-26-2017, 02:51 PM
1Hotrodz
1Hotrodz's Avatar
I would make sure that all the needle bearings are accounted for. first find out how many are missing then count the ones in the oil pan. If you can't account for all the needle bearings, all is not lost. I can say with 99% certainty that the unaccounted needle bearings have no chance of being sucked up by the oil pick-up tube, sent to the oil pump and filter and circulated thru the engine oil galleries, if that's what your worried about.
Old 07-26-2017, 03:12 PM
Tennispro1986
They said it was just one of the rocker arms and it was only a few of them and they were accounted for. I'm just over worried now.
Old 07-26-2017, 03:14 PM
spartan8270
spartan8270's Avatar
I've run int o the same thing.The last two oil changes I have flound a needle bearing stuck to the drain plug. I have upgraded to the CHE trunion kit a while back so im not worried and the heads have been off. If they are in your pan the pick up screen wont allow it to be sucked up and it;s pretty common in an LS to find needle bearings on drain plug. Just make sure you upgrade to a good trunion kit like CHE and pull valve covers and inspect thoroughly for anymore needle bearings. Not as big a deal as you think. Since you are having the heads pulled and fixed I def wouldnt worry about it
Old 07-26-2017, 03:19 PM
Tennispro1986
Yeah I am having all the rockers replaced and this is all happening while the heads are off so everything was inspected and they said it was just tje one rocker.
Old 07-26-2017, 03:25 PM
Jjagg0125
Jjagg0125's Avatar
This is scary... who makes the best mag drain plugs?
Old 07-26-2017, 03:33 PM
RedZ4me
RedZ4me's Avatar
If I recall reading this, the earlier (06 to maybe 08?) has the factory one as magnetic. Later GM went to a std one as every little bit caught on the plug caused an uproar in the corvette world.
I could be wrong, again recall reading about this. So if true, buy an early oem plugs.
Old 07-26-2017, 05:06 PM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Screen on the oil pump pickup is so fine a needle bearing will just float around in the pan.
To Needle bearings found on drain plug
Quick Reply: [Z06] Needle bearings found on drain plug
