Possible opportunity to buy 2012 ZR1
So I have always loved this car for the obvious lovable reasons. I may have an opportunity to get a very low mile example. What is the good, bad and ugly to know? I read here on the this forum section that there was a clutch issue that resulted in a GM bulletin being sent out for the fix. Is there anything else I should be aware of? I appreciate the comments, thanks
Model year 12 and 13's are the gems of the C6 world, with the interior updates and upgraded stereo. If it's a 3ZR than it's got the nice leather interior package. While every car is subject to mechanical anomolies, I don't think there really are any big deal breakers for a 2012 LS9. The LS9 is probably more durable than the new LT4, certainly in the heat.
Thanks Big Vette. All the info I can get is great.
It's not a clutch issue. It is the clutch slave cylinder. Gm has a service bulletin on this issue. They will fix for free. Only other issue will be valve guides. If you have never driven a ZR1, you will fall in love after the first drive. Torque from start to stop.
GTRSOLO (07-27-2017)
Thanks for the info, so what's up with the valve guides?
The LS9 is based off the 6.2L LS/LSA motor where as the LS7 was an entirely all new block, cylinder heads, etc. While there may not be as many high mileage LS9/ZR1's out there to look at, there are a slew of high mileage LSA's in CTS-V's and ZL1's and it's nothing that would or should make someone decide not to buy the vehicle. The LS engine is perhaps the best pushrod overhead valve V8 engine ever created, including the new LT series motors in the C7's with direct injection and cylinder deactivation. No engine is exactly bullet proof, but the LS engines are pretty damn skippy.
The LS9 in our ZR1's are great engines so don't worry about them. If it's a car you like and the price you like then buy it and start enjoying it. Just so you know there were 2 different gearings in 2012 and 2013. For an additional cost you could get the performance package which should be clearly shown on the window sticker. As a quick reference the rear spoiler will be black if it does have that option regardless of the color of the car itself. Of course, if this is a black car you're going to need the sticker. The 2012 and 13 also have 4 cats. These are great driving cars!
Good luck !!
Good luck !!
Good luck !!
Good luck !!
Enter the last 4 digits of the vin after going here. You can see a good amount of detail sometimes:
http://www.corvetteactioncenter.com/...rowse_2012.php
