E85 Injectors
JaredW (08-15-2017)
I generally use a 60 lb injector for N/A E85 LS7s. They flow enough to make 650whp without an issue using a Walbro E85 450lph pump. 850cc work too but are more then is needed NA
JaredW (08-15-2017)
My car has Bosch 52lbs injectors. Running E85 and made 624 rwhp. Everyone says they are to small but my tuner who is well known said they would be fine. Dyno day he said there was no issues.
JaredW (08-15-2017)
JaredW (08-15-2017)
So I may be okay with LS9 injectors then, I doubt I will crack the 600whp mark. When my tuner and I talked about it, he said that he thinksg he can get another 7-8* of timing in it with e85 so I should see a decent result.
Did you get yours from the group buy they have on the forum right now or order from them direct? If I end up needing something other than LS9's I have used their injectors in the past and had no complaints with them, so I wouldn't hesitate to run them again. Especially at that price point!
Ran their 1200cc versions on my turbo 04 cobra also with no issues.
The spray angle is off and on top of that the above post was referring to a 52Lb injector at 3 bar of pressure which flows more like 60lb in an LS fuel system at 4bar.
Wasn't there a thread a while back about the "Bent angle boogyman" and clocking the injectors a bit to reduce the angle? Then again there may not have been any truth to that.
You literally can't be ID injectors. I was very reluctant to go this route based off of cost, but had used other brand injectors in the past and driveability suffered thereby. I have a gigantic NA cam and the car has fantastic idle and off throttle manners with ID850s on 93 and e85 as compared to LS9 injectors previously with a smaller cam.
Another good rule of thumb is to size your injectors close to your needs - too big is such a thing when it comes to injectors. ID1050s on an NA setup is way overkill and only complicates things at low fuel demand, even with e85 or e98.
Yeah I think you are right about them not making anything smaller anymore.
