[Z06] LS7 Schematic that includes pin-out for the ECM
Trying to solve a throttle position sensor code for another forum member that is still popping up after he's already replaced both the throttle body and throttle position sensor. Hope he can use a multimeter
Thought I had that schematic but damned if I can find it.
https://ls1tech.com/forums/conversio...ml#post7009337
65 Throttle Position Sensor 1 Signal
Here is a link to some good 2006 engine schematics.
http://www.corvetteactioncenter.com/...trols-207.html
That's the ticket. Now just need to hear from the person with the issue.
He has not posted in his own thread in a few days.
Need one more. Looking for the internal ECM schematic. I need to know if there is multiple voltage regulators for +5 vdc reference voltage.
The throttle body sensors share a +5 source but the throttle position sensor (pedal) comes in on two different wires. If the +5 volt is not the same on both then the sense voltage will be off and will set a CEL.
