Normal or not?
Normal or not?
So my cammed 09 z06 with longtubes and no cats seems to puff a little smoke. Only does this at wot and at higher rpm. It smells like fuel. All fluid levels are perfect on the car and it runs amazing. Had a buddy tell me its just fuel. Any truth to this? Car has ahp fixed heads along with btr vlv train components. Id upload a video if someone can point me in the right direction.
So this the dyno video of how the smoke is. Any input? Smells like fuel as mentioned. Tuner left it a little fat as leaning it didnt gain us anything accept a little knock. So fattened back out
Black smoke is fuel and blue smoke is oil.
Watch your oil level very close.
Pro Mechanic
Pro Mechanic
A "decent" tune would not be rich and WOT high-rpm. With an N/A LS7 a good tuner is going to try for .85-.87-lambda across the rpm range when in PE.
Supporting Vendor
Received 1,012 Likes
Looks like excessive fuel from your video.
Tune needs work.
http://www.americanheritageperformance.com/
Tune needs work.
Little confused, by making an assumption here, you have one of the best tuners in the country, what did he say? What was his recommendation? There is more to this story.......
corvettenutz (09-05-2017)
i had one of the best tuners i believe tune my car yes. He didnt really comment on it. He had me video it a few times so he could see if tgere was any detonation. He also said some smoke more then others he never said that i should worry or that i should do anything.
Contacted the builder of my car. He also said that he wouldnt worry with it. That it doesnt look bad to him. He knows these engines very well. He had until just recently the fastest 6 speed z06 1/4 mile time, and currently has 8 or more vettes he is working on. So i trust the tuner and builder completely. However im just a lil worried as i dont have 15k to spend on a rebuild or worse lol.
I suppose it could be as simple as a whack injector or an unbalanced injector system. I don't think you have any problems or anything to worry about. My 600 whp LS7 make a little fuel smoke in certain situations. My brand new Camaro makes alot of fuel smoke under right foot load.
i think u may be right. It has more if im in nuetral and rev it to 5500 or 6k rpm with the clutch depressed then under a load on the road. I cant even tell if im on the road at all. Only if at a stop and rev in nuetral so its not like its bad enough to see on the road with wind moving.
This is from bluecat himself directly As far as the smoking on the dyno in the vid, thats pretty much just a function of the condition of the motor. Some dont smoke at all, some more than yours. All in all thats fairly typical and dosen't really imply there is a problem.
