[ZR1] Timing chain tensioner...
Doing heads and cam install in my zr1 and a few buddies with a c6 and ctsv mentioned to me a problem with the ls3 style tensioner that we have in our ls9. I guess they tend to fail a lot especially after a cam install... has anyone on here experienced any issues? Are you modded guys still using your oem tensioners or did you switch to the ls7/ls2 dog bone style dampener?
The LS7 specific dampener which is required when used on a dry sump LS7 require the yellow dampener (GM 12581276) as it is 1.1mm thinner so that it can fit with the LS7 2-stage oil pump. The reason for the two different colors was for the assembly line at GM, so they could readily tell which ones were which.
Found a little info (and pics) over here on how it works on the LSA motor.
http://www.ctsvowners.com/forum/4-en...ide-issue.html
https://www.corvetteforum.com/forums...ing-chain.html
Use the LS7 style on LS9 due to the dry sump style cover
