[Z06] Spring life (when to change valve springs?)
#102
Awesome, sounds like a killer setup. My 383 for my drag car is spec'd for ~600hp but has yet to see an engine dyno. GenII LT1 block, 12:1CR, , GTP ported AFR220 heads(227ccs after porting, flow 330cfm@.7"), maxed out supervic, .73x race solid roller. I'm thinking it will be closer to 650 since it was a little overbuilt.
The lift is not the primary deciding factor in valvespring wear, it is the ramp rate of the lobe - how fast it gets there. A .650 lift cam with a mild lobe and the right spring can have little to no reduction in valvespring life vs an OEM setup.
Technology has advanced a lot in the last 20 years and I would not expect ANY hydraulic lobe to eat a set of quality springs in 15k miles. Even the more aggressive HR grinds are relatively mild off the seat compared to a solid roller. We are talking street cars here, not 8500rpm race motors that only see a few minutes of run time between rebuilds. If you are only getting 10-15k miles out of your valvesprings on a hydraulic roller street car then you are not running the correct parts.
