[Z06] Ticking noise after head swap
Thanks all for the comments and suggestions.
My plan of attack is to start with the easiest/lowest risk item which is the exhaust. I've found a shop that will work with me this weekend on detecting any leak source(s). I properly torqued header bolts with the new GM gaskets so I don't think that's where a leak could be, but I still won't rule it out yet.
After that I'm interested in the shorter pushrods and possibly the trunion upgrade idea. Could just putting in shorter pushrods help? That's an easy test to try. Any other thoughts on this?
If that doesn't work then I'll pull the heads. Really regret not inspecting the lifters on the first go-round. Good lesson for others considering a DIY head swap.
Will update as I learn more.
You mentioned you get a smell in the cabin. What kind of smell (oil, gas, coolant)?
I don't think you will solve this with a shorter pushrod - it's common knowledge that running less preload can result in more ticking and tapping noises, not less.
I am waiting on my heads from AHP and have new lifters coming even though I am not changing cam. Lifters are cheap enough even though old lifters only have 12.5k miles. Also my heads were milled .020" and recommended to use 7.775" PR which seems to the norm.
It's hard to describe but basically the smell reminds me of running exhaust with no cats. Goes away after 20 seconds or so after startup and it's pretty strong outside the car. At the moment it's the one thing keeping me thinking it's an exhaust leak and not lifter related.
If you have a shop vac, or regular vacuum that can be reversed to blow air:
stuff it into one of the tailpipes and seal it as best you can. Ditto for the other tailpipe. Blow the air into the exhaust system and check for air leaks.
I listened to the video again. It sounds like a lifter, especially how the noise increases with rev and lowers when idling. However with exhaust gaskets being fairly cheap, I would replace DS exhaust manifold gasket first and see if that helps.. Did you remove any other exhaust gasket?
