C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
ZR1 air filters
Old 09-25-2017, 10:02 PM
Zr1ny
1st Gear
Zr1ny's Avatar
Default ZR1 air filters
2009 zr1.
Worth replacing air filter with k&N???
Seems like after market companies like Hennessy change out the stock filter.
Old 09-26-2017, 08:41 AM
BigVette427
BigVette427's Avatar
I have a 2012 Z06 that came with the ZR1 air filter and I like it a lot. Personally, I'm not interested in the 10hp tops that may be had with an aftermarket CAI.
The only bad thing is Donaldson/GM did a disservice to the ZR1 community when they stopped making the ZR1 filters with the larger pleats, but still try and sell you the inferior LS3 air filter under the same part number that the previous ZR1 filter used to come in. Spend $100k+ on a ZR1 only to have GM give you a cold shoulder a few years later, that's how much GM cares.
https://www.corvetteforum.com/forums...r-filters.html
SIK02SS
SIK02SS's Avatar
Spend your money on the Attack Blue filter (just google it in conjunction with Corvette or ZR1 and should pop up- a few site sponsors also sell it). It'll save you the headache of over over oiling the filter (messes with MAF) and is a proven filter/minor power added.
Old 09-26-2017, 10:40 AM
big_mike_eu
big_mike_eu's Avatar
I am due for an air filter replacement on my 08 Z06. I was intending to buy the ZR1 filter from GM, but thankfully came across this post. Do you know if the Attack Blue filter will fit on a Z06 (assuming it will due to the similarities of the two cars but thought I'd double check before I spend $175 on a filter LOL)
Old 09-26-2017, 11:02 AM
SIK02SS
SIK02SS's Avatar
have no idea. I was looking into filter changes when I got my ZR1 which is how I learned of them, and then I realized previous owner already installed one. If you find which vendors carry it I'm sure they'll have an application guide per sey
Old 09-26-2017, 11:09 AM
big_mike_eu
Sounds good, thanks for the quick reply SIK02SS
To ZR1 air filters
Quick Reply: ZR1 air filters
