[Z06] Weight difference between stock rotor and baer two piece rotors
I just ordered Baers two piece rotors for front and back for my 08 ZO6. Does anybody know the weight difference between the 2 front rotors and the back rotors? Each?? I think the stock front ones are 26 LBS each. Baer website does not give the weight.
Don't recall seeing specs on those...using stock calipers correct? I imagine you'll realize some weight savings over OE rotors. Coleman two piece shave ~32 lbs off the car at all 4 corners, while racing brake's two piece rotors shave ~26 lbs off the car. If the Baer's aren't in that range, I'd say cancel the order and go with one of those instead.
Received 2,061 Likes
Reducing weight with rotors is a crap shoot. The important part to understand is how the weight distribution is from the center. If the majority of weight reduction is near the hub, taking the carpet out of the truck/hatch is probably more effective.
If you want to drop weight with rotors, swap to base brakes and save caliper weight too.
I hope your comments were meant to be tongue and cheek! Either way, it's all good.
Tom is spot on actually. And for someone wanting straight line/drag/etc base brakes are a much better "upgrade".
I noticed no difference at all doing the light weight rotors. The weight is all around the center, so it is no where near the same as remove weight from a wheel/etc.
Wrong... Switching from factory Z06 rotors to lighter aftermarket rotors (from PerformanceFX) can save as much as 6lbs of unsprung weight per corner, which is equivalent to removing over 100+lbs of sprung weight. It's a noticeable performance improvement on a Z06. Also, replacing the factory aluminum six piston calipers with cast steel single piston "base brakes" would be an absurd modification. I never heard of anyone doing that to a Z.
441LSXTT (10-03-2017)
Everything I read supports unsprung weight being significant help. More so on road course but also in straight line performance.
Any runs to back up either way?
Regardless, I didn't see where the OP said anything about drag racing his Z.
I have not heard this side of the story either to be fair. I would be interested in the science behind this as I was planning on dumping 2K into AFX rotors this winter if I didn't find a set used.
If we are talking unlimited budget, go ahead, do them.
If you are talking max performance for the dollar, and his concern is only straight line, he can sell the stock z06 brakes for $100, spend $200 on base brakes, save more weight and have $800 to spend on other parts.
Or he can spend $800-2000 on something that is basically does nothing.
I do have the colemans on my car, been there done that, one of the most useless mods I've done. I rather have a few nicer steak dinners than waste that money again.
And you say superior rotors? In what way? For drag racing, the base rotors are going to be better. Less weight, and less MOI.
In theory do they help, yep. Is it noticeable in any way, not at all. Go ahead and spend $2k on them if you want, but odds are you won't notice a thing.
Nope, because they are on there and I don't want to mess with my car.
They are at the bottom of $/performance ratio of any mod I've ever done, by far. If you are find spending that money, go for it, but there is simply better places to put $2k into the car than rotors, that wear out.
hpwizard.com/rotational-inertia.html
Base rotors for drags work well (Norm with 9.46 @ 139.80 #2 on the internal list), but suck for the road course where heat is the enemy.
If you're interested in some static weight testing for drags, I did this several years ago.
https://www.corvetteforum.com/forums...ght-tests.html
