C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Texas Speed 4.2 cam results
Old 10-22-2017, 02:35 PM
jayyyw
jayyyw's Avatar
Default Texas Speed 4.2 cam results
I’ve been trying to find ways to make more power without tearing into the motor but I kept coming back to swapping cams. After a lot of back and forth research, I decided on the new TSP 4.2 grind. It’s one of the most aggressive OTS grinds out there, under .660 lift. I had Pat G spec me a custom cam and still, ultimately, landed on the TSP cam.
Unfortunately, I don’t have a true back-to-back comparison. I changed to a vararam Intake after my initial tune and never put it back on the dyno to see the difference. From everything I’ve seen, the vararam dynos 10-15whp less, on average.
Original setup was:
LPE ported heads
.050” mill
BTR Stage 3 cam
TSP 1-7/8” headers
Halltech 103
Mamo MSD
NW102 TB
e85
577/544
Current setup is:
LPE ported heads
.050” mill
TSP 4.2 cam
TSP 1-7/8” headers
Vararam Intake
Mamo MSD
NW102 TB
e85
Lost a little torque down low over the last setup but carried power further up.
Here’s the SAE graph
Overall, I’m happy with the swap. Drivability suffered a little bit. I can probably have it smoothed out a little more but it’s not a huge deal. Idle sounds pretty damn good compared to the last cam.
Gained about 1.5 cars in Mexico against a comparable, consistent car. Can’t complain with those results.
​​​​​​​Not sure what to do next.
The following 2 users liked this post by jayyyw:
dmartens (10-23-2017), Evan Sanza (11-01-2023)
Old 10-22-2017, 02:41 PM
Drew03tx
Drew03tx's Avatar
Very cool! I have a custom cam from performance hq in San Antonio that shares a very similar grind as tsp 4.2. I made 585 without milled heads and on 93 octane with 75% humidity. Hope to get over 600 with e85 and better weather. I didn't know you could mill heads .50 I thought the most you could go it .30
Old 10-22-2017, 02:46 PM
jayyyw
jayyyw's Avatar
Are you from SA?
I don’t think you’ll gain 15whp on e85 unless, for whatever reason, your timing table was not maxed out for pump gas.
From what I’ve read, you can go .060”, flat mill, without having issues with the intake manifold lining up. You can angle mill the heads up to 13.8 compression, maybe even more.
Old 10-22-2017, 05:45 PM
QwkTrip
QwkTrip's Avatar
You can but it hurts flow and is of diminishing returns. The best way to bump compression that high is with different piston profile.
Aftermarket heads are the next step, if you want to go there.
Old 10-22-2017, 05:53 PM
RedZ4me
RedZ4me's Avatar
Is that mould behind the monitor on the wall? Not good
Old 10-22-2017, 06:07 PM
jayyyw
jayyyw's Avatar
Mamo TFS are on the list. Just not “next”. I’ll likely try a 2” header, different axle-back, and more weight reduction. Still waiting on the release of the gearsets and trying to decide between a 3.90 and 4.10.
Old 10-22-2017, 07:15 PM
Drew03tx
Drew03tx's Avatar
Are you from SA?
yes I'm in SA
Old 10-29-2017, 04:53 PM
Da Z06
Da Z06's Avatar
Good gains.
I'm in SA as well. We all need to link up.
PHQ does great work. Shawn's tunes my car.
Old 10-29-2017, 05:39 PM
jayyyw
jayyyw's Avatar
Originally Posted by Da Z06
Good gains.
Definitely down for a meet.
Old 10-29-2017, 09:00 PM
Drew03tx
Drew03tx's Avatar
Good gains.
Yup that’s who did mine
Old 10-29-2017, 10:00 PM
Turbo2L
Turbo2L's Avatar
Awesome numbers my friend! Time to stick the GoPro on the side and let her eat.
Old 10-30-2017, 09:06 AM
jayyyw
jayyyw's Avatar
Thanks man. Already in the works!
Old 10-31-2017, 11:15 PM
Mattd19902010
Mattd19902010's Avatar
I'm also in sa do y'all go to san Antonio raceway
Old 11-01-2017, 12:35 AM
Drew03tx
Drew03tx's Avatar
Every now and again
Old 11-01-2017, 09:22 AM
jayyyw
jayyyw's Avatar
I've been a few times.. Looking to hit it up more now that the weather is getting nicer.
Old 11-01-2017, 12:05 PM
Mattd19902010
I pretty much go every other weekend I need to get some drag radials I'm still on runflats
Old 11-01-2017, 12:25 PM
jayyyw
jayyyw's Avatar
I'm selling my rear Racestars with 315/35/17 MT Street S/S mounted on them. Let me know if you're interested.
To Texas Speed 4.2 cam results
Old 11-01-2017, 12:33 PM
Suns_PSD
Suns_PSD's Avatar
Are you from SA?
I gained 14 rwhp/ 17 rwtq on an NA 500 hp LS3 pretty much across the entire rev range, FYI. It's a BIG 14/ 17 too as the motor runs much 'sharper' on the E85 it's very noticeable.
Old 11-01-2017, 03:39 PM
jayyyw
jayyyw's Avatar
Was your pump gas timing maxed out? Heads milled at all? There are plenty other benefits to e85 than just power.
Old 05-09-2018, 08:27 PM
2012_7.0
2012_7.0's Avatar
Original setup was:
LPE ported heads
.050” mill
BTR Stage 3 cam
TSP 1-7/8” headers
Halltech 103
Mamo MSD
NW102 TB
e85
577/544
Current setup is:
LPE ported heads
.050” mill
TSP 4.2 cam
TSP 1-7/8” headers
Vararam Intake
Mamo MSD
NW102 TB
e85
just installed the 4.2 TSP. Curious what pushrod length you went with?
Quick Reply: [Z06] Texas Speed 4.2 cam results
