How many miles on your LS7?
80k miles, drivetrain is stock other than oil cooler thermostat, no problems encountered other than failed fuel level sensors, all valve to guide clearances within service limits when checked at 62k miles.
2006 z06, 73k miles, 2nd owner. Heads were replaced under warranty due to out of spec guides at 57k miles. no issues ever, have done approximately 25 track days, two cross country road trips, 30 drag strip passes, countless autocross events...
07 z06 31,000 miles 2nd owner. bought it in jan 2017 with 21,000 miles six speed. corsca pipes, kenwood deck and 1000 watt kenwood amp from previous owner.
everything on LS7 stock as far as i know.. drive it every day...it has been something my son and i enjoy together.had no idea how fast z06 was until test drive..WOW...
2009 Bone stock with 55,000 miles. Best car I have ever owned.
2006, 45k. Wiggle test at 30k showed a few valves at or just over the limit so they went off to AHP for some work (MS90 + .030 mill). Other than that, just headers, MF103 and a tune.
#35
early 09Z bought used stock at 8500 miles, full HCI done at 46K miles, now at 55K.
OEM cat replaced for check engine light then ECM reflashed when 2nd check engine light came on and I showed the dealer the GM TIL that said not to replace cat for that code. Battery replaced in 2015.
#36
13Z original owner 20K+...Stocker..
#38
Stock cam here, too. I went with a .040 head gasket so I should be close to 12:1 (I think?). I ran the details past Kohle and he didn't see a problem. I have easy access to 93 octane gas, though.
