How many have weighed their Z06 after XXX mods?
This is what my setup looks like
Yes, those are the ones
XS Power 586 Tall Brass Post Adaptor (M6 Thread)
The brackets you want to use for the post (which should be included with the battery) are like this...
Does this battery work for everyday usage if kept on the charger when stored?
I have been looking at another lightweight battery but dang it's expensive. About $800 all in.
when I park the car in the garage, I simple attach thew power cord to my retractable troublelight that hangs from my garage opener.
FRCEFED (12-07-2017)
I run a Shorai in my motorcycle, have been using it for years. I use their battery charger/tender, bike is always plugged in when not in use. I like it but, iis very sensitive to cold temps though, when it's below 50 deg I have to turn on the headlight for about 30 seconds to "warm up the battery" before it will crank the starter motor. Are the larger automotive sized Shorai temperature sensitive also?
#33
I went with a 205/50/17 Hankook for my 17x5s. That tire is lighter and speed rated higher than the Roadmaster tire you have. I'm running 315/35/17 Street Rs in the back.
I plan to get AFX rotors for the front, 15" conversion for the rear, light battery, carbon hood, carbon hatch with poly-carbonate window, and a few other things here and there. I'd love to be at 3000lbs with me in the car. I try to race the car with, at most, half a tank of gas.
I'm dropping another ~30lbs in a week by switching to the LG GT4 axle-back, from the ZR1 OEM mufflers.
#35
I'd love to run a smaller battery but I live in an apartment with no garage. I do drive the car everyday, tho. Not sure how that battery would hold up to that.
Alternatively, I don't know if it would be worth the hassle to swap it out every time I race the car.
#36
The apt with no garage I understand as you’d want to def keep it on a charger when not in use. But why would you have to swap it out to race the car?
#37
I meant if I were to have the OEM battery in the car, daily. Since I don't have a way to keep the Shorai battery on a charger while it's installed in the car, I'd have to swap to the lighter battery when I go out and play.
#38
Really want weigh savings where it counts first...welds alumastars shiny 10lbs each...minus 8 lbs off your skinys..bias ply fronts equals savings also...your forgestar rears are about 25lbs...c5z fronts are 19lbs another 12 lbs where it counts...your 325 tire is what? A 34 lb tire? Hoosier 315 is 24lb..another 20lb off...your skinys tire is what? Could be 50lbs of rotatational unsprung mass off right here...it's like removing a person in sprung mass from your car...gl
