C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Can't inflate the tires
Old 12-09-2017, 02:23 PM
khoeysr
Corvette fan
Support Corvetteforum!
khoeysr's Avatar
Default Can't inflate the tires
Went out to air up my 13 ZR1 and my 15 Z06. Last couple of days have been cold, low 30s. Today bright but cool- middle 30s.
The Z06 went fine, but 3 out of the 4 ZR1 tires would not show a pressure and would not accept air. Took it for a short spin to see if the valves were possibly frozen. Tossed a cup of hot water. Nothing.
Anybody ever encounter this?
(As an aside, I just replaced the battery and the tire pressure display has the front and rear tires swapped.)
Old 12-09-2017, 03:49 PM
Ron'sGS
Ron'sGS's Avatar
Just curious, did you use a tire gauge to verify the pressure in your tires?
Old 12-09-2017, 04:48 PM
khoeysr
Corvette fan
khoeysr's Avatar
nothing registers
Old 12-09-2017, 07:47 PM
bgad
bgad's Avatar
I guess you have runflats?
Old 12-09-2017, 11:51 PM
khoeysr
Corvette fan
khoeysr's Avatar
yes they are the original equipment tires. Car has about 3900 miles.
Old 12-10-2017, 10:15 AM
seijack
seijack's Avatar
Yes, I have had this happen!!
If you have valve stem caps that have rubber o-rings in them check to see if the o-ring has stayed in the valve stem when you removed the cap, you will need to look very closely..
To remove the o-ring from the valve stem, find the smallest pin or in my case I used the smallest Allen wrench and depress the air inlet valve (some air will escape) once you depress the valve enough to get below the o-ring just pop it out.
Good Luck
Old 12-10-2017, 11:25 AM
Pounder
1/4 mile/AutoX
Pounder's Avatar
Received 2,081 Likes on 1,634 Posts
Good Luck
Old 12-10-2017, 12:09 PM
khoeysr
Corvette fan
khoeysr's Avatar
Good Luck
seijack, you are the man. . That was it.
Thanks a million for being on here and seeing my post and solving my problem.
Old 12-10-2017, 08:03 PM
seijack
seijack's Avatar
Khoeysr,
No problem!! I am glad that I was able to help...I had that happen to me last summer as I was getting ready for a trip, it took me about an hour to get it figured out.
Merry Christmas!!
Old 12-10-2017, 11:17 PM
LMB-Z
LMB-Z's Avatar
A 13 ZR1 and a 15 Z06....life must be rough...lol!!! Do you need any kids???? I can be adopted
Congrats...glad you got it sorted out.
Old 12-11-2017, 09:44 AM
khoeysr
Corvette fan
khoeysr's Avatar
Dude, I have a lot of first world problems as well as corvessive compulsive disorder.
I am beginning to think about trading both vettes on a new ZR1.
CorvetteDan06 (11-29-2021)
Old 12-11-2017, 12:50 PM
Too-Fast
Too-Fast's Avatar
And I thought I was the only one with this problem!
To Can't inflate the tires
Quick Reply: Can't inflate the tires
