Mamo Motorsports LS7 package / 200+ RWHP Gain!!
I need a Z06 with this combo. Badass as usual Tony.
Supporting Vendor
Hey,
Finally got my 2007 Z06 back to the track with all my Mamo goodies...
Setup as follows...
2007 z06, mamo top end kit, heads, mamo ported msd intake, his rockers etc, 1 3/4 LG long tubes through converters, mamo spec'd cam 238/252 on 114, 315/35/17 hoosiers on c5z fronts, vararam intake, NW102 throttle body, 2012 mufflers... STOCK CLUTCH... which will help explain the ET.
Track is 3 hrs each way from my house, so I wanted to be able to drive home. I launched at about 2500 rpm... no slipping and when clutch was fully engaged got into it. First time being able to see what it had as the car on street tires is almost useless(1st and 2nd). Pilot super sports 345's. The car pulls hard!
60ft - 1.9562
1/8 - 7.2352 @ 108.12
1/4 -10.783 @ 140.63
As you can see tons left in it. I reviewed the data from the runs and I was shifting early as well(6900) limiter is set at 7200... so some there as well. Air was good 550-600 ft, so not crazy air, but good.
Amazing how this car pulls on the back half. Had more then one person come up to me and say, supercharged?
Anyway, wanted to share as 140mph is pretty stout and I'm sure with a clutch that I feel comfortable with, more aggressive launch and shifting it a bit higher, low tens and 143/144 is within reach.
If you are looking for a N/A setup that straight out runs talk to Tony... you will not regret it.
Cheers,
Alex
Setup as follows...
60ft - 1.9562
Cheers,
Alex
Regards,
Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
TRSCobra (12-15-2017)
Here is a quote directly from one of my customers....note this car is probably 20-30 RWHP lower than combination featured in this thread. Not to mention a soft launch and one of his first trips to the track with the new combo (may have been his first). A better clutch and more technique/practice would easily put this car in the 142 MPH range being conservative and it's not nearly as optimized as the build featured in this thread.
DSGCOBRA24 (12-17-2017)
That has not been my experience, my highest trap speeds are always recorded with my best 60 ft times. If this guy trapped 140 with a 1.9x short time, then he can easily go 142-143 with a decent launch.
Z06Qazi (12-23-2017)
#33
#34
Seb's previous record was 9.53@145.86 i was there every minute of that day helping him out with tire pressures, lining up in the groove and telling him when to let off on the burnouts. Same thing goes for his new record of 9.35@153.75. I've been involved with seb for the past 3 seasons and I swear on my 3yr olds daughters heads there's no cheating going on. We've put together another car Alexgz06 and it went 143 without headwork and untouched msd intake. Alex left tons on the table considering he still has roughly 40rwhp in heads, ported intake, ati pulley, and a better set of headers and he still traped 143 with a bog off the line. Instead of calling bs just because you didn't or can't, maybe go back to the drawing board and figure out what you're not doing or doing wrong. Sebs not gonna spell it all out for you
RobGOV-DCZ (12-19-2017)
#36
#37
If Gary can trap just shy of 140mph with just bolt ons then what's another 5mph with a worked set of heads and cam on top of that? The timeslips have been analyzed by one of the best and the record stands. Seb has worked his way up the ladder over the yrs in multiple categories and this isnt some overnight success story. You are intitled to your opinion and I respect that. You don't have to get cute with your "eh" though.
Congrats for this build, definitely making some nice power. Can't wait to see some track numbers.
#38
very impressive numbers. Definitely believe this car is very capable trapping 142-143. I like that fact that its not on a solid roller setup too.
#39
This wasn't my intention to highjack the thread it was just an observation as to someone wanting to see 145mph+
Don't get upset when I throw a quip back at you after you insinuate I have no other reason to question the legitimacy of the time, "because I didn't or can't" do it.
Since you guys are in the marker for new heads, you might as well give Tony a call.
#40
Supporting Vendor
Guys,
Lets try to keep this thread somewhat more on point.....LOL
Records at the dragstrip are all well and good but that is a "study" and a science in and of itself.
Getting down the track quickly is alot more than just power....race weight (which Im sure is optimized in anyone serious enough to be record hunting), aerodynamics, chassis and suspension mods to help weight transfer, and shear skill and determination (aka tons of practice)....not to mention air quality a huge variable. Lets face it, your never going to set the record in Southern California or Florida but ALL of the variables I mentioned come into play here.
Bottom line....Im selling most of my heads/cam packages to your average enthusiasts who simply want to go fast (some simply wanting an impressive looking dyno sheet in their glove box to share with the boys at Sunday's "Cars and coffee" event).
But when you see a significant trend where 3rd party independent dyno's across the country are breaking records with my Mamo Motorsports LS7 combinations (typically with significantly more power than seen previously), that certainly means if a track rat got hold of my combination they could really exploit it's possibilities and lay down some serious numbers.
I know of numerous enthusiasts I have helped with my new LS7 gear running 140+ but alot of these guys prefer to be low key and not talk about their results on the forums as a majority of them street race and would rather keep things on the down low for obvious reasons. The guys that run for money will certainly never post and other guys just like to walk softly and carry a big stick just for the surprise factor and fun of it all even if money isn't involved.
I have decided to force myself to invest the time required to finally modify my own C6Z. She was a honey pot virgin I picked up with 1800 miles on it a couple of years ago (it's a machine silver 2008 2LT). It was bone stock and still smells new inside....a collector had grabbed it and it sat in a heated steel building with about ten of his other automotive possessions. I shipped it from the east coast back to LA and have only put a couple of thousand miles on it myself having limited "personal time" available mainly due to running this business and helping you guys go faster! (I do have a 700 RWHP CTSV to keep me smiling when I feel the need for speed....LOL).
I plan to chassis dyno this car on two seperate dynos bone stock....pull the engine.....dyno test it on a SuperFlow engine dyno in bone stock trim....exhaust manifolds and all.....and then install one of my own MMS LS7 heads/cam packages and then back to all three dyno's once it's tuned and dialed in. Its alot of work to do all this but the data from all of this will be meaningful and worthy of the time invested. Then it's off to the track to run her down the quarter mile a few times and certainly a half mile event thrown in as well. I don't expect to set any records here is So Cal air (1500 above sea level is a good day!) but I assure you the track results will be impressive if you factor in the air quality the days I will be attending them (which I will record and document with my weather station).
Im looking forward to all this hardcore R&D almost as much as Im looking forward to the way the car drives with another 200+ at the rear wheels!! Im actually surprised how fast the car is in bone stock trim and have been door to door with boosted C7's numerous times in some highway roll ons. The C6Z is really an awesome machine....the most pure sports car GM has ever built IMO with the classic powerful N/A / lightweight build approach....now that almost everything seems to be supercharged these days the engineers designing these cars dont need to be as creative....just add another pound of boost to carry that extra 75 lbs....LOL
Anyway.....Im looking forward to 2018.....I have alot of unique customer builds in the works as well as my own C6Z which is going to be a bonafide super car when Im done with it
Cheers,
Tony
Cheers,
Tony
