C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track Advertisement
Quick review of Toyo R888R on a street car (ZR1)
Old 04-15-2019, 12:39 PM
  #41
Craiger77
CF Senior Member
Craiger77's Avatar
Liked 18 Times in 13 Posts
Originally Posted by VelocityC6z View Post
I noticed your tires are mounted on the wheel so the tread pattern is different on both sides. My tire place mounted them differently, so all 4 tires are the same.
Now I’m wondering if mine are mounted wrong? I thought they were designed to only me mounted one direction. Mine being the same on all 4 I’ve never noticed any weird pulling to one side or the other, I haven’t tracked the car yet to tell if it’s going to make a difference or not yet either.
I have R888R's and my installer raised concerns about the asymmetrical tread pattern also. He insisted that I had purchased 4 "passenger side" tires. I called Toyo and they confirmed there is only one tread pattern and it will appear to be reversed from side to side due to mounting. The important mounting step is to be sure the large tread blocks are on the outside and the narrow blocks are inside. The tires must be mounted with the "outside" lettering facing out according to the Toyo rep I spoke to
Craiger77 is offline
Old 04-15-2019, 01:43 PM
  #42
LS1Steve
CF Senior Member
LS1Steve's Avatar
Liked 52 Times in 43 Posts
They are asymmetrical. Same deal with NT01's.
LS1Steve is offline
Old 04-15-2019, 09:17 PM
  #43
chandretti15
CF Member
Liked 7 Times in 7 Posts
They are asymmetrical so they will not look the same from the left side of the car and the right side of the car. The tires are marked “outside” on the sidewall. Your installer did not follow the directions.
chandretti15 is offline
Old 04-15-2019, 09:18 PM
  #44
VelocityC6z
CF Senior Member
Support Corvetteforum!
VelocityC6z's Avatar
Liked 30 Times in 24 Posts
Yep, he sure didn’t lol
VelocityC6z is offline
Old 04-16-2019, 02:17 PM
  #45
Frankie15
CF Senior Member
Frankie15's Avatar
Liked 290 Times in 243 Posts
Thanks for the review! Planning to get a set of these when I need to replace the MPSS'. Seems like they should definitely be capable of hooking in my HCIE setup. MPSS' are nice, but not great in terms of hooking when nearing 600 rwhp.
What sizes would you all recommend for stock Z06 wheels? I'm interested in stepping up to the 345s in the rear, but not if it will have a detrimental effect anywhere.
Frankie15 is offline
Old 04-17-2019, 09:23 AM
  #46
0H8Z06
CF Senior Member
0H8Z06's Avatar
Liked 568 Times in 486 Posts
Frankie.. do the 345/30/19's and don't look back... I am running the 4S's on my stockers (stock sizes) on all 4 corners. I need some rear tire tires for traction... Car corners awesome... but tires spin in 2nd pretty bad...
0H8Z06 is offline
The following users liked this post: 0H8Z06
Frankie15 (Yesterday)
Old Yesterday, 05:59 AM
  #47
Frankie15
CF Senior Member
Frankie15's Avatar
Would you also go with 285s in the front to accommodate for the 345s in the rear? What size exactly would be optimal for front tires if going 345/30/19 in the back? Thanks bud!
Old Today, 08:25 AM
  #48
cmb396
CF Senior Member
cmb396's Avatar
Liked 8 Times in 7 Posts
CI 7-8-9-10 Veteran
I am going to go with these next on mine. I have MPSS on the front, and Sport Cup on the rear, and the care handles and rides great, no road noise, BUT, traction is super limited at 620/550. I thought the Cups would hold better, but I have lost traction at 80+ with a 2-3rd shift. It will hold 1 and 2nd if i gently lay into it, but any punch of the throttle and they blister. This is on heavy ZR1 repros, and I just picked up a set of super light Rennen Concave wheels that weigh much less than the repros. Mine is not a dd, just a once a month (if I'm lucky) weekend warrior.
cmb396 is offline
Old Today, 09:01 AM
  #49
Verrückt ZR1
CF Senior Member
Verrückt ZR1's Avatar
Liked 237 Times in 194 Posts
I run the Toyos on my '09 ZR1. Absolutely LOVE them. The only complaint I have is that they're a little noisy. 285 fronts, 345 rears.
Verrückt ZR1 is offline
Quick Reply: Quick review of Toyo R888R on a street car (ZR1)
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
