C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
What size tires for 19/20 set up?
Old 01-13-2018, 10:50 AM
GeneSch
GeneSch's Avatar
Default What size tires for 19/20 set up?
What size tires are you guys running in 19/20 set ups.
I want to put the largest sizes that will fit. Really looking for a little more height. I don't want to lower the car so a little taller tire may fill the gaps better.
Old 01-13-2018, 01:50 PM
Tech
Tech's Avatar
This is a common topic. How much power?
1MEANGS (04-18-2020)
Old 01-13-2018, 03:20 PM
GeneSch
GeneSch's Avatar
740 to the tires. I know the won’t hold the power for racing. I will have a set for that. I want these for DD and road trips.
Old 01-13-2018, 03:49 PM
Tech
Tech's Avatar
If money is no object, R888R is what I’d try. They are grippy, taller, can be driven in light rain if you get caught, and don’t compromise lateral stability.
Old 01-13-2018, 07:51 PM
GeneSch
GeneSch's Avatar
I’m going to have a drag set up for street n strip. I need something good for long drives, back roads and what ever els we may run into.
Old 01-13-2018, 07:59 PM
Tech
Tech's Avatar
“Whatever else” is the variable. Michellin Cup 2s are what I ran for about a year on 19/20 combo with 650 rwhp. They were fine for spirited back road driving but weren’t that great for highway pulls.
Old 01-17-2018, 01:55 AM
ben410
ben410's Avatar
Mickey Thompson ET Street SS is what I'll be running next. Currently on Michelin Pilot Sports and they can't grip that well. Currently putting down 560 rwhp.
Old 01-18-2018, 12:01 AM
Blk 08 C6
Blk 08 C6's Avatar
Ill be trying those r888r I believe 315 30zr 20s.
Old 01-18-2018, 01:42 PM
htvette
htvette's Avatar
Toyo R888R has a 325/30/20 size which will be my next rear tire change.
Old 01-18-2018, 01:57 PM
Tech
Tech's Avatar
Some info on Toyo tire sizes for those interested in them...
https://www.corvetteforum.com/forums...post1596275852
You have a few different combinations of tire sizes that will work.
Old 01-20-2018, 11:10 AM
Apocolipse
Apocolipse's Avatar
Received 1,282 Likes on 927 Posts
Those of you that are not getting grip with the mpss or cup2...what kind of pressure are you running and how cold is it outside?
Old 01-20-2018, 12:18 PM
Tech
Tech's Avatar
32-34 psi.. all year in the midwest. Anywhere from 30* to 100*.
Old 01-20-2018, 04:29 PM
Apocolipse
Apocolipse's Avatar
Thank you for the reply. I know these tires like to be at ~34psi when hot for best grip and not more...perhaps it would be worth while trying to run 28 om the street.
Old 01-20-2018, 06:39 PM
hotrod03
hotrod03's Avatar
I have ZR1 wheels 19 and20
345 rear
285 front
Wide body 427 vert
Old 01-22-2018, 02:47 AM
Vestor
Vestor's Avatar
You've got to be very careful on the height ratio between front and rear or you will throw off the traction control. Trust me I had this happen. I purchased a set of tires that had the wrong ratio because I wanted as big as I could get. I now have 19/20 and went with 285/335 which is the stock setting for ZR1. Works fine. I think the height difference front to back needs to be about .8-1.25 inches...so make sure you keep about in the range.
Old 01-22-2018, 08:42 AM
Apocolipse
Apocolipse's Avatar
Is it like the C5 where it will cut power thinking there is wheelspin and apply brakes?
To What size tires for 19/20 set up?
Quick Reply: What size tires for 19/20 set up?
