Using dynamat to reduce heat/ sound in C6 Z06
Hello
I have a 2009 modded z06 which is getting ready for headers.My carpeting is starting to pull away from the lower console area.I have an EE tunnel plate with the ceramic coating.I have been told to use dynamat under the carpet to control heat and sound.Has anyone done this and what amounts were needed?There seems to be Dynamat extreme,dynamat superlite and dynamat liner?
Thanks.fitz
Thanks.fitz
Get a pre-cut kit like this one: http://www.exoticvette.com/c6-insulation-kit.html
There's another kit out there as well that offers door panel pieces in their kit...name escapes me at the moment.
My .02. If you are going to go to the trouble of installing either the precut insulation or Dynomat, go ahead and install both. I actually did 3. Sound deadener, vibration damper, and the insulation. I liked the results.
(Factory Carpet)
Insulation
Vibration Dampner
Sound Deadener
(Factory floor)
With sound deadener being the Dynamat, what vibration dampener did you use?
Hello
Thanks.fitz
Thanks.fitz
Just a note the antennas for the radio FM/AM are attached to the rear trunk release bracket and go through the rear panel then horizontal left and right so if you run a sound absorber material that has a foil on top you will effect the radio reception I peeled the aluminum top layer off my insulation which was Lowes duct liner so it only goes part way up the rear panel to get back the lost radio reception also raised the antenna wires by taking out the rear tailights and you can see the antenna wires moved them up and taped them down. The wires are a red one for AM and green for the FM diversity system.
