Just took the plunge.. ordered the quickjack 5000
well I just finally grew a pair to make myself order the quickjack I been eyeballing for a few months. im hoping it allows me to learn how to work on the z06 and my daily driver. First job is removing the super dusty squeaky OEM brake pads and putting on carbotech pads. I wanna learn to do basic things. and it will help allow me to clean and detail the car without laying my butt on the floor working on the wheels.. hopefully its not a disaster. my Daily driver needs a coolant flush and break stuff. I made the hockey puck jack pucks. I gotta read up on all the torque specs and just go slow and teach myself how to do the basic installs and maintenance. of course this site has a abundance of reading that is giving me the courage to get wrenchin!
Keep us updated once it arrives. I'm curious to know if the initial set up is easy or somewhat involved. Also, I'm in the same boat as you. I have limited experience working on cars, which stops at oil changes and tire rotations. I'd prefer to work on my car myself and this jack would certainly help. I was eyeballing it too but haven't pulled the trigger yet.
I would also like to read your update. Been thinking of getting something like this as the tried and true floor jack and jack stands method I have been using for 40 years has gotten old!
Received 1,678 Likes
2018 C6 of Year Finalist
St. Jude Donor '10, '17
Very nice. I have one and love it. I literally use it every week during the racing season, and during the off-season I have had the car sitting on it for months at a time while performing major work. It is extremely safe, easy to use, stable/sturdy and works exactly as described. I have attempted to push my car right off it just to test it and it will not budge.
Set-up is straight forward. Plan on it taking a solid afternoon. The instructions aren't perfect but are adequate. You will need some very basic hand tools/wrenches and an air compressor. Also make sure you buy a few quarts of Dexron III or Dexron VI synthetic ATF. It doesn't come with it and it needs it. It is standard hydraulic oil found in any automotive parts store.
Also, make sure you lift and lower it a number of times before you put a load on it for the first time. You need to get the oil primed through the lines. When you do initially engage it without a load (for priming), the lift will appear to operate erratically (one side goes up faster than the other and may not come down easily). This is normal as it typically needs a load (weight) to operate properly. But you still need to do this initial procedure to prime it. Again, it will seem to be acting erratically but is part of the setup process.
If you need any help setting it up feel free to message me. Also, for lifting your car or any type of work you are performing feel free to message me if you have any questions. Happy to help in any way that I can.
slappy3347 (02-21-2018)
once set up they are a blast....its the set up and dragging/rolling them into place that's a pain
That said, as I value my life and I know that any part can fail, when I am actually underneath the car wrenching I also place jackstands as another backup. So for the car to fall the locking bars must fail, the hydraulics must fail and the jackstands must fail. In other words, the end of the world.
I was skeptical at first when these started becoming popular a few years back but I definitely plan on getting one of these now.
Due to the locking tab design, just like a large lift, if the hydraulics fail the vehicle is still not in danger of falling. Like Mordeth stated above the hydraulics are not what keep the vehicle suspended like with a floor jack. I actually saw a video where they used a forklift and overloaded it to something crazy like double its rating and it still didn't collapse. Much safer than floor jacks.
Received 1,679 Likes
Those are my DRM's Anthony....
Nice! I've been looking at those since the summer. Where's the best place to order? Isn't there the taller version for SUVs? I would think that would be better to allow more room under the car.
I'm curious about Snaps' question regarding being able to do a clutch job.
I have a quick jack and max jax. Both are great. I use the quick jack way more often.
Yes you can easily do a tranny job. Worst case get the height adapters and you can get it really high off the ground. Lift it up, set it down on jackstands/ramps, then install adapters, then lift again. Not needed but an easy way to get it even higher.
You only need the SLX version for our Vette and most cars/trucks. That's the one you buy. If you have other vehicles you want to use the jack on, simply measure the distance between jacking points. As long as it is 60" or under then the SLX is fine (will be the case for most cars).
