Battery Hold Down for Lithium batteries and OEM style
Hey everybody,
Just out of curiosity, would anyone be interested in purchasing either OEM style battery hold down brackets or one designed specifically for the Shorai LFX36L3-BS12 battery?
For anyone curious, they would be 3D printed out of ABS+ material using our Fortus 250mc.
I designed one for my new Shorai battery as I didn't want to add a bunch of foam into the battery compartment, install anything using rivets and bolts, buy the Katech foam kit, or pay for one of those expensive brackets from Braille. The Shorai battery does come with foam, but it's not enough to fill the entire compartment and neatly secure the battery in place.
While at it, I decided to design one similar to the OEM hold down as well, in case I ever lost the original and needed a replacement. Figured I'd ask if there was interest in something like this before I print out a one-off for my battery. I could also design one for a different battery if there's interest, as I'm not sure what other popular Li batteries people are running with. Both are designed to bolt down on the original threaded rods that are in the battery compartment from the factory. I designed it with the intent of an easy swap to the smaller Shorai LFX36L3-BS12 battery.
Simply remove the OEM hold down, pull the old 36# porker of a battery out, dropping in the new lightweight Shorai 5# battery and clamp it in place with this Shorai specific hold down.
Let me know what you guys think.
Surprised that no one has offered a quality solution like this before.
Price it right and I think it will do very well.
I wonder if one could be made for the Optima red and yellow top size #34 to make them compatible with our cars?
Thanks for the suggestion on the Optima batteries. I'll look into those and see if I can find some dimensions on them.
How much would it cost roughly? Something I've been interested in doing (super lightweight battery) when I get a DD.
I hate to go off topic slightly, but do cars with the Shorai battery need to be on a tender whenever they're not being driven? What if it gets driven daily?
Odyssey Battery PC1200MJT
- LWH - 7.87 x 6.66 x 6.80
- Weight: 38.2lbs
Duralast Gold
- LWH - 9 1/2 x 6 7/8 x 6 7/8
- Weight: 29.70lbs
Optima Yellow Top 3478DT? D34?
- LWH - 10.06 x 6.94 x 7.88
- Weight: 43.5 lb
Optima Red Top 34R (R34-980)
- Weight: 37.9 lb
I will try to get more exact numbers tomorrow so that I can commit to a claimed cost though.
If you plan to DD the car with the Shorai, it should be fine without a charger. And it'd be able to sit over the weekend (or a couple days during the week) as well. But due to these cars not completely shutting down, in order to run the alarm and keep the clocks/computers updated, it should be put on a charger if the plan is to sit for a week or more. If there is no draw at all on the battery (removed from car and properly stored) it can last up to a year before fully discharging.
You can use a normal battery tender on it as long as the tender does not have a de-sulfation phase in it's charging cycle, but it's recommended that if a charger is necessary for your situation, that you use the Shorai specific charger.
This might help, per my research...plus a couple of other battery measurements just in case it is helpful to anyone.
- Weight: 38.2lbs
Duralast Gold
- Weight: 29.70lbs
- Weight: 43.5 lb
- Weight: 37.9 lb
- Weight: 38.2lbs
Duralast Gold
- Weight: 29.70lbs
- Weight: 43.5 lb
- Weight: 37.9 lb
At first glance, it appears that I could somewhat alter the existing designs to fit all of them. Not positive about the Optima batteries, but I'll see what I can do.
Frankie15 (02-27-2018)
I don't have costs nailed down exactly, but I figure $12 - $15 a piece shipped via ground shipping to the 48 depending on volumes. Best guess as of now, I could hit about $12 if I can print 10-12 pieces at one time that people are already in place to purchase. I'd really prefer not to print a huge volume of them just to guarantee a lower cost if there's are no potential buyers lined up and end up having to shelve inventory. Especially since I have no idea what kind of inventory turn over rate a part like this would have.
Thanks for the info.
I'll get confirmation on a piece cost by tonight and let you guys know
I just realized I had a typo on the price I guesstimated. I meant to put $22-25. The original post stating the $12-$15 cost has been updated.
I will post on here again once I finish crunching the numbers to get an accurate amount to quote.
Okay guys, just finished crunching the numbers and unfortunately my guess was off. These parts require a bit more material than I initially anticipated and with that, a higher cost to produce.
That said, I can do $40 each delivered to your door anywhere in the 48 via USPS Priority 3-Day.
I need 8 people minimum lined up to make that price happen. Whether it be:
- 8 OEM replacement
- 8 Shorai LFX36L3-BS12 style
- 4 OEM, 4 Shorai
- 6 x 2
- 1 x 7
- etc.
Also, some options for customization:
Personalized Text - add $5
C6 Crossed Flags Logo - add $10
If you would like a customization other than what is listed above, let me know and we can discuss cost based upon the complexity of the request.
Send me a PM if you are interested and I will provide paypal info so that payment can be made for whatever options you'd like. Deposits are to be made in full and will be held for a minimum of 15 days to allow time to acquire the necessary number of buyers. After 15 days have passed, if the necessary number of buyers has not been reached, I will issue refunds in full unless the buyer is willing to hold out a little longer.
Hold down brackets for other brand/model batteries are currently being worked on and will be available at a later date.
If you have any questions, let me know.
Nathan
- 8 OEM replacement
- 4 OEM, 4 Shorai
- 6 x 2
- 1 x 7
- etc.
Nathan
I don't know if that did, but we are a site sponsor, and we have quite a few Lightweight battery options...
you can check us out here... and see our latest battery in the video below.
https://shop.antigravitybatteries.co...es/automotive/
I saw these at PRI last year and I was pretty impressed. I previously did a product review for the XP-1 jump starter and it has worked awesomely. I have used it to jump start a Silverado 3500 HD Dually with no problems. My point is they make some good quality products and I am going to take a second look at the battery.
Thanks, appreciate it.... we'll be there again this year... have more cool stuff coming out. Doing some new 16v for drag Cars, some new sizes of Auto Batteries too.
