[Z06] 700-750 Lift cams
700-750 Lift cams
Just out of curiosity what do you guys need to change to run these high lift cams to not get side load or valve float. just rockers and some lifters?
You need a stable lobe and light Ti valves and good springs and definitely decent shaft rockers with a roller tip like the Jesel Sportsman or better or crower steel LS7 rockers or T and D etc. and also a nice heavier wall 3/8ths or larger diameter pushrod in general. With a more rigid rocker you can run a little stiffer valve spring to control the higher lift motion better. Better yet get some spintron time with a professional or copy a known system or ask someone like Comp Cams Billy Godbold what is even in the ball park. It's a complete and total system you are looking at and of course it's never cheaper to have more lift AND more reliability!
427V8BB (03-05-2018)
not sure on the lifters and rockers, I have a 660 lift cam and use stock rockers and lifters, just changed the pushrods and valve springs. Look up some valve springs that have the correct spring pressure for that high of a cam
dont know honestly wanted a mean sounding cam mean while at 11.0 compression then do a blower down the road ported heads and headers 1-7/8 B and B haltech intake stock intake and TB wanting 550whp. Then when the blower goes on I’ll change pulley and cam to a boosted one. While staying on the safe side of side loading cam for mpg also cause 8mpg can’t do it for now lol. I really wanna try tracking the car once.
With a 770 lift cam I would just save money and keep the stock valve train. You will hate the car so much you will never drive it anyways.
Seriously though. You've been posting questions all over the forum that obviously show you don't really know what you want or need. You should sit with someone who knows what they are doing and discuss your goals for the car, and have them help you piece together the proper combo to get there. It really sucks to spend all kinds of money and then not like the results.
Reliably a OE rocker arm doesn't like to go much past 0.650-0.660 lift or it starts to hang at the end of the rub pad and can start doing some weird things.
I understand Comp Cams is working on OE style rocker arm that should be able to go past that and correct some of the geometry issues but nothing has been said as to a price or release date yet. http://markenperformance.com/n-9281-...e-springs.html
That is about all I have seen showing it. Again nothing official has been posted.
You would need to take a very careful look at the valve stem length, seal install height, coil bind and make sure that nothing is going to crash into itself when you start talking about big lift cams. Other than the the rocker that is going to be the harder part to get setup right.
Billy at Comp would be a good contact to speak about it with too.
T@D makes a bolt on roller tipped rocker for rules restricted engines that run + .700 lift. With that much lift though, the engine built requirements will start snow balling real quick. Don't do it. Totally unnecessary.
was thinking of making a e85 monster NA Build with a fat cam but who knows all ideas mostly likely I’m gonna stay with a smaller cam like a btr4
Jesel does as well and they are super nice and around $255 ea rocker ($4000 a set)
This ^^
http://www.dragzine.com/features/pri...ms-from-jesel/
Those...called on them just a few months ago. Biggest reason is that they are a steel rocker which is always going to be more money than the aluminum ones just due to machine time and material.
