C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Aldan Coil Overs
Old 03-20-2018, 10:19 AM
Pounder
1/4 mile/AutoX
Support Corvetteforum!
Pounder's Avatar
Received 2,082 Likes on 1,635 Posts
Originally Posted by 2FastCorvette4U
I wouldn't mind seeing a pic of the drop these coilovers are able to do.
Funny !!! I keep trying to raise the car !!!! We are tired of the scraping on the bad roads here in OK. I want it about 5/8 above the tires, running 315's on the front and 335's on the rear we need some clearance,we are running 18's on the back so it's low to begin with. you could go as low as you want with these !!!!!
Old 03-23-2018, 12:04 PM
Wasserott
Wasserott's Avatar
Originally Posted by Pounder
just got back from another test run, drives a bunch firmer, I would guess the bushings would add to the firmness (plus the tires were up to 34 psi) ?? still not happy with ride height, back on the ramps !!! we are running Rival S ,,, 315/18 in front and 335/18 in rear !!!
Drives firmer than what??? Stock Z06? What spring rates did you get?
Chuck
Old 03-23-2018, 01:44 PM
Pounder
1/4 mile/AutoX
Pounder's Avatar
Chuck
more firm with stock springs and larger front sway bar and duel adjustable shocks, 500 front and 550 rear
Old 03-26-2018, 12:47 PM
Pounder
1/4 mile/AutoX
Pounder's Avatar
Well, after our first AutoX event the Vette performed unbelievable !!!! we felt like in the turns we could be almost as aggressive as we wanted. never felt the Vette wanting to push or slide out, other than trying to control rear tire spin on a cold semi-wet track everything felt great !!!!!
Old 03-27-2018, 10:02 AM
Pb82 Ronin
Pb82 Ronin's Avatar
sub'd
Old 04-10-2018, 10:25 AM
2FastCorvette4U
2FastCorvette4U's Avatar
I would love to see any pics of the drop these coilovers are able to do.
Old 04-10-2018, 02:37 PM
Pb82 Ronin
Pb82 Ronin's Avatar
Curious why poly bushings instead of Delrin or monoball?
Old 04-10-2018, 03:01 PM
Pounder
1/4 mile/AutoX
Pounder's Avatar
price and availability !!! when we took the car apart we noticed the stock upper control arm bushings were working their way out, we had a dead line for our first event !!!!
Old 04-10-2018, 03:37 PM
Pb82 Ronin
Pb82 Ronin's Avatar
Understood. $$$ always sucks.
Old 04-10-2018, 03:49 PM
Pounder
1/4 mile/AutoX
Pounder's Avatar
coilovers, then need bushings, then end links, after we already had headers,Vararam,cam,all new brakes,seats, don't want to know what everything adds up to ?????
Old 04-10-2018, 03:51 PM
MTPZ06
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Poly is usually a good upgrade over rubber bushings...initially. Only knock I have against Poly is that its prone to cold flow; meaning repetitive stressing in the same direction will cause the bushings to distort over time, as poly lacks the elasticity of rubber (ability to snap back to its original shape).
Old 04-10-2018, 05:01 PM
Pounder
1/4 mile/AutoX
Pounder's Avatar
oem is nothing to brag about, IMO ????? (we will see about the poly's ???) also think the control arm movement is better with the poly ????
Old 04-10-2018, 05:10 PM
  #33
MTPZ06
MTPZ06's Avatar
Agreed that they are an improvement over OE rubber bushings, far less bushing deflection...they just aren't a forever fix. I used extensive amounts of energy suspension poly stuff back in my off roading days, and I've seen plenty of round holes become oblong/egg shaped.
This will take a bit of time though, so again...you're good to go for quite a while. If this is becoming your track car, I would just say add these bushings to your routine track prep/inspections season by season to evaluate.
Pounder (04-10-2018)
Old 04-10-2018, 08:36 PM
  #34
Pb82 Ronin
Pb82 Ronin's Avatar
(Opinion piece) For control arm bushings, I will ONLY go with Delrin. The amount of stress the control arm bushings flex is very surprising...even with poly's. I ran them in my Cobra since about 25K miles (now with 75K miles) there is still ZERO noticeable deflection. And I'm happy to report that noise difference was not any harsher than stock. Given dynamat works wonders.
Old 04-10-2018, 08:52 PM
  #35
Mordeth
Mordeth's Avatar
Received 1,678 Likes on 878 Posts
2018 C6 of Year Finalist
St. Jude Donor '10, '17
The problem with poly is that it binds, gets chewed up and needs servicing and replacement. So you skip poly and go to delrin, which is 100 times stiffer than poly and more durable. But if you are going to go delrin, you might as well go aluminum - which is ~30 times stiffer than delrin for the same approximate NVH as far as feel goes (most people can't feel the difference) yet is superior to delrin.
Straight from rubber to aluminum (monoballs) for me. Do it once and be done. No reason to go poly when there is delrin, and no reason to go delrin when there is aluminum. At least not for a car that is either raced or driven hard. You can debate it (cost, availability etc), but it doesn't change the facts.
By the way, this has been debated here for years and years (like our heads).
Old 04-10-2018, 08:56 PM
  #36
MTPZ06
MTPZ06's Avatar
I wish Global West made their Del-A-Lum bushings for our cars. I'd run those in a heart beat...damn near indestructible. Ran their stuff on an F-body back in day...completely transformed the handling/traction/etc of that car.
Old 04-10-2018, 09:38 PM
  #37
Pounder
1/4 mile/AutoX
Pounder's Avatar
this is a DD and we don't want it to drive like a truck with 900 compound tires !!!!!!!!
To Aldan Coil Overs
Old 04-11-2018, 12:00 AM
  #38
Pb82 Ronin
Pb82 Ronin's Avatar
I agree...but I also prefer delrin versus heim joints on a street car. Just preference.
Old 04-11-2018, 06:17 PM
  #39
Mordeth
Mordeth's Avatar
No idea what this means. Did someone tell you that spherical bearings make a car "drive like a truck with 900 compound tires"? You certainly didn't test this yourself, as you would not have made such a ridiculous statement otherwise. Adjusting tire pressure will have more impact on what you can feel as compared to spherical bearings.
Old 04-11-2018, 09:24 PM
  #40
Pounder
1/4 mile/AutoX
Pounder's Avatar
this was what I was referring to ??? "Straight from rubber to aluminum (monoballs) for me. Do it once and be done. No reason to go poly when there is delrin, and no reason to go delrin when there is aluminum"
Quick Reply: [Z06] Aldan Coil Overs
