2007 ZO6 LS7 Rob Cam ?
LMB is my favorite C6 Color, I saw your photo with the Headlands, are you close?
I would talk with Matt @ GPTuning about your cam desires as you will need
a tune as well after install. A lot of the sound can be influenced by the tune,
lower idle RPM and your exhaust.
What else have you done for 600 RWHP?
Need a lot more info. What mods do you have? What are your goals? Are you willing to give up all street manners? Give up highway cruising?
Tick Performance has a cam they have advertised lately that offers good lopey sound but the hp increase was less than you would have expected based on sound. Usually that type of cam gives good drivability. Check theyre website. usually a cam designed for power creates some drivability issues at slow and highway speeds and its hard to tune out those issues (usually surging)
I'm not sure but that sounds right. you can search tick performance cam on facebook and see a vid
I hate to be that guy but no it didn't. If you have a dyno saying it did, the dyno operator played with the weather settings in the dyno to produce a very inflated number. Bolt on cars aren't making 600 at the flywheel, let alone at the wheel.
