C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
Mamo HCI going for a retune today
Old 03-21-2018, 01:36 PM
Jayfabs
Jayfabs's Avatar
Default Mamo HCI going for a retune today
On my last trip to the dyno I made 624rwhp and 529rwtq. Since my last tune I have added a Mamo RPS clutch and swapped from a Vavaram intake to a halltech mf103 with the Vette air scoop. Stay tuned I will post results later. Here is a picture of how my engine bay is looking these days and my first dyno graph. I will be on the same dyno today roughly same temperatures but more humidity.
Old 03-21-2018, 01:40 PM
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Nice! Sub'd
Old 03-21-2018, 02:21 PM
encasedmetal
encasedmetal's Avatar
What are you doing for the intake shroud since moving to the Halltech. I ask because Halltech told me I'd need a new uncut shroud when moving from a vararam to a Halltech due to the position of the maf.
Old 03-21-2018, 02:25 PM
MTPZ06
MTPZ06's Avatar
^Radiator shroud? Looks like he already replaced his, and then added the vette air scoop.
Old 03-21-2018, 02:28 PM
Jayfabs
Jayfabs's Avatar
yep I bought a new shroud.
Old 03-21-2018, 02:45 PM
nuke61
nuke61's Avatar
sub'd
Old 03-21-2018, 03:22 PM
jayyyw
jayyyw's Avatar
in.
Old 03-21-2018, 03:24 PM
encasedmetal
yes that's what I meant. saw his reply as well. it was hard for me to see with the screen i was looking at.
Old 03-21-2018, 03:33 PM
07427z
07427z's Avatar
Sub'd
Old 03-21-2018, 04:35 PM
Navy Blue 210
Navy Blue 210's Avatar
In for Results.
Good Luck
Old 03-21-2018, 08:11 PM
Jayfabs
Jayfabs's Avatar
Ok results are in not what we were expecting. My tuner and Tony feel the car is restricted somehow. Have to start looking into a couple things but it still makes great numbers. I picked up 5rwhp and 10rwtq at peak. There was more power under the curve though.
Old 03-21-2018, 08:27 PM
beavisr1
beavisr1's Avatar
What clutch did you swap out for the Mamo RPS?
Old 03-21-2018, 08:46 PM
MTPZ06
MTPZ06's Avatar
Really? What were you expecting?
Old 03-21-2018, 09:06 PM
Jayfabs
Jayfabs's Avatar
I swapped out a stock clutch. I was hoping 640
Old 03-21-2018, 10:35 PM
nuke61
nuke61's Avatar
The swap to the Halltech, IMO, is a non difference, but I would have expected more from the Mamo'fied clutch. My guess is that the gain is actually there, but the correction for the additional humidity is the cause of what looks like a tiny gain. In any case, you still probably have among the higher N/A LS7s where you live!
Old 03-21-2018, 10:42 PM
Turbo2L
Turbo2L's Avatar
What cam? Headers? Cats? Previous clutch? What rear tires? Results seem on pay with rotating mass reduction. Swap to 2-piece aluminum hat rotors on the rear axle and pick up another 8-10rwhp.
Old 03-21-2018, 11:50 PM
rio95
rio95's Avatar
With Dyno variation I don't think you should be bumped one bit. Interesting inatke switch. I went the opposite way with no regrets yet.
To Mamo HCI going for a retune today
Old 03-22-2018, 12:23 AM
Jayfabs
Jayfabs's Avatar
I hated the look of the vavaram. That’s why I switched
Old 03-22-2018, 12:24 AM
rio95
rio95's Avatar
With some black couplers I think it looks pretty good. According to my testing it simply performs better for me so it's staying even if it is a touch uglier.
Old 03-22-2018, 12:26 AM
Jayfabs
Jayfabs's Avatar
I have the standard Mamo package. I was on the stock clutch before. I also changed from the stock 325 run flats to 345 NT05R since last dyno pull. Cam is a 244/258 114+3
Quick Reply: Mamo HCI going for a retune today
