[Z06] group 48 battery
Here, I just took these pictures at work. As big of a pain in the butt gettin
g my normal battery out of my z06, I cant imagine fitting a bigger one in there like a 48. I know its kind of an awkward picture to get the difference in size but I highly highly doubt you could get it in there.
I work for my uncles automotive wholesaler. Metro Detroit. Getting stuff at cost is very nice.
It’ll be too tall for the battery compartment to close all the way. Dimensions will be very tight otherwise. A group 47 will be a better fit, still height issues though
1972bluelt1 (04-07-2018)
Pro Mechanic
If you want a better battery for a ZO6, try the Odyssey PC1200. That's what I've been using for several years. Much higher pulse cranking rating means it will spin the engine during cranker at a faster RPM.
Just changed the out the battery in the Z06. As usual now that it's done, I know how to do it. Pulled up the carpet, the door and frame. Made a lot more room plus I could get the cables out of the way.
