Safe minimum oil temperature?
“Safe minimum running oil temp” I’m guessing when I say 160F before running my LS7 higher rpms. I’ve always took it easy until 175F. So gear heads what is your opinion what my oil temp should be before I lean into “it”. My tuner installed a 160 stat
And on days of mid 40s it takes awhile to get my oil temp up. Mobil 1
0-40 euro oil is the oil suggested.
160 t stat just cause premature wear on motor. For oil temps 160-170 is a good range to start getting on it.
hotrod03 (04-11-2018)
I generally wait until at least 160° but curious to hear other opinions. I know guys at the drag strip that only wait until the car is at a minimum operation temp (like 1st pass off the trailer) without much regard to oil temps, before letting it rip.
160* oil is a good minimum to start getting on it. I look to get to 160* early in a warmup lap and then it will quickly climb to 200*+
hotrod03 (04-12-2018)
Received 2,061 Likes
10.80 @ 126 LS3 bolton.
Open road in 110* ambient with 160 stat runs about 180 coolant. Same heat in rush hour stoplights can top 240.
I've never seen less than 170 coolant even at freezing temps. A 160 stat gives you a running chance to stay under 200. The stock 186 stat will always push you over 195 in the first mile.
From decades of road racing 140 degrees works. Never hurt a motor starting at this temp. Multiple mechanics have recommended the same. We do not run stats but do keep cardboard around!
Steve
Steve
Received 1,679 Likes
EDIT: Just for reference, I have the stock 187 degree thermostat in my car. With the help of my Dewitts, the car runs right around 190-192 on the street all day long. If I had a 160 thermostat, it would still run at 190-192 degrees.
Not true, the thermostat only starts opening sooner, so there's virtually no way that the coolant will stay at 160 F because of hysteresis. A simple thermostat like that will always have an offset, and the lower limit to cooling will be the radiator. If his radiator is up to the task, it could easily drop his running temperatures in the Phoenix summers from 220 F to 190 F.
To the radiators capability, which it would be somewhere 200-240F
Higher, no
Quicker to get there, maybe depending on current setup.
So this proves your 160 thermostat does nothing to help in cooling. If it did, your car would run at 160 degrees. Your thermostat has nothing to do with your car running at 180 degrees. It fully opens at 160 degrees, so cooling at that temperature and above is solely based on your system's efficiency - radiator, airflow, coolant, etc. You could have put in a 180 degree thermostat and your car would have run the exact same temperature.
Why the bigger radiator? Wasn't the OEM keeping it cool enough? I'm betting you don't drive in 100-120* extremely low humidity weather very often?
I know when my brother did a big radiator, upgraded cooling system on his GTO, and a 160 t-stat car would run right at 160, heater would never get hot, and car would get **** mileage, never exit open loop, etc. If you have excess cooling to be able to run on the t-stat temp, then you would not want to run at 160 either way.
The point is that anything you do to reduce the coolant temps will also reduce oil temps. All heat you create with your car, eventually dissipates into the air. You can only change the rate. T-stats automatically control the upper or lower limits of the rate.
