C6 Corvette ZR1 & Z06 General info about GM’s Corvette Supercar, LS9 Corvette Technical Info, Performance Upgrades, Suspension Setup for Street or Track
Sponsored by: Kraken
[Z06] Motive 3.90 and 4.11 Gears IN-STOCK
Old 05-21-2018, 08:14 PM
  #141
dubaitacker
dubaitacker's Avatar
possibly for me i run a 335 x 30 x 18 rear tyre so i didnt want to put the 4.10 gears in
i would have a simular gearing with that tyre to running the 4.10 gears on a stock size wheel and tyre
Old 05-21-2018, 08:31 PM
  #142
427V8BB
427V8BB's Avatar
how does the 4.10 gears feel to the regular 3.42 does it throw you in your seat harder when you have traction?
Old 05-22-2018, 07:05 AM
  #143
dubaitacker
I haven't really booted the old girl yet to scared shyteless about the valve guides with the wigge test results.....
Im not running any mods to the engine that I have worked out yet, think its standard with a tune. If it is standard the tuner thinks it would be around 560hp at the engine as that's what his car made with the same tune. Though we have 98 pump gas at every fuel station so I guess its has a bit of advance tuned into it as I was told to only run that fuel.
Had a few half hearted attempts and I would have to say its going to be have considerably more push into the seat than before, and its is going to drop right into the middle of the sweet RPM range on the upshift.
Old 05-23-2018, 10:51 AM
  #144
blkscls1z
blkscls1z's Avatar
Came in earlier this week. Planning on putting it in next Monday.
Old 05-24-2018, 02:18 AM
  #145
REDZED2
REDZED2's Avatar
That's not a C6 Z06 diff though. Unless I'm blind. 3.90s should pull hard anyway!
Old 05-24-2018, 08:56 AM
  #146
blkscls1z
blkscls1z's Avatar
It's hard to see the top in that pic, but it is in fact a C6Z diff. I removed the diff cooler. Don't need it for drag racing.
REDZED2 (06-03-2018)
Old 05-25-2018, 08:27 AM
  #147
xowhitegenxo
xowhitegenxo's Avatar
When I lived in bahrain I remember getting the Mumtaz pump gas and it was 98. I had my motorcycle with me at the time and it ran really well even in those hot summer days/nights.
Old 01-20-2019, 03:00 PM
  #148
jimbob8915
jimbob8915's Avatar
On a Z06 is there a different oil or modifier necessary for break in?
Old 01-20-2019, 03:14 PM
  #149
AzDave47
Support Corvetteforum!
AzDave47's Avatar
Received 4,506 Likes on 2,597 Posts
Originally Posted by jimbob8915
On a Z06 dont the differential an transmission share the same lubricant?
no, they are separate units with the tranny bolted to the dif, but separate cases. They also take different fluids. The dif cooler uses the cool tranny fluid from the radiator to cool the dif fluid, but again the fluids are on their own side of the heat exchanger.
Many of the car mags call it a transaxle, but it is not a true transaxle.
  #150
Mike44665
Mike44665's Avatar
No. Better research this before you tear into it. It is quite a job, you will end up with the transmission supported and sliding the diff off of the output shaft to the rear of the car. Harbor Freight lift table is the way to go. A floor jack just won't get it.
Old 01-21-2019, 05:58 PM
  #151
Pb82 Ronin
Pb82 Ronin's Avatar
Subbin'...I need 3.90's in my life.
Old 03-27-2019, 08:36 AM
  #152
redbird555
redbird555's Avatar
Just wanted to bump this thread. I'm having my 3.90s installed by a local Corvette shop and I was wondering if those of you who had the installs done replaced the pinion bearing assembly?
If the hearings are in good shape my guy says they'll be fine to reuse which I know is normally ok but just seeing what others did
Old 03-27-2019, 10:12 AM
  #153
Mike44665
Mike44665's Avatar
The pinion bearing is already assembled from GM. It is two opposing tapered rolling bearings with the correct spacer calculated and installed. This setup allows you to torque the nut the crazy torque required. If you have it in your hand, or they have it in their hand, considering the cost to get to this point, I believe it would be a very big error not to replace it now.
My $0.02.
Old 03-27-2019, 10:16 AM
  #154
Mike44665
Mike44665's Avatar
Here is a picture.
Old 03-28-2019, 08:33 PM
  #155
redbird555
redbird555's Avatar
New pinion bearing on order... I cant find the nut however in stock anywhere. I understand that many say reusing the old nut is fine. Can anyone confirm? In pics I've seen it looks just like a metal nut so I don't see why not?
Old 03-28-2019, 09:22 PM
  #156
No Lemon
6th Gear
No Lemon's Avatar
Is there a install kit with bearings and whatever else comes with it available or do you just piece it together? I called Summit and they to call the dealer?
Old 03-28-2019, 09:42 PM
  #157
Mike44665
Mike44665's Avatar
This is the answer you're looking for.
It MUST be set up correctly or you'll fry the bearings right now. This is why it is an assembly, GM removes the chance of and error and disaster. You can't over tighten the nut and hurt the bearings with the GM assembly.
To Motive 3.90 and 4.11 Gears IN-STOCK
Old 03-28-2019, 09:57 PM
  #158
redbird555
redbird555's Avatar
Don't mean to be rude but I'm not sure if this was answer to me about the nut or lemons question.
In the rebuild procedure I have I the gm manual it makes no mention about replacing the nut just to inspect it upon removal for any issues. I assume that means it's good to reuse?
Old 03-29-2019, 08:26 AM
  #159
Mike44665
Mike44665's Avatar
I apologize for the confusion. I should have stated the reply was for "no lemon". You can't buy the bearings and put them in the housing, it even states that in the manual.
As for the nut issue, these things are torqued to 370 foot pounds. As long as it come apart with no issues. When something is that tight, obviously there is a lot of pressure of the threads. If the threads start to tear or snag the nut is useless. I went with a new nut as to avoid this if it did occur. When spending this amount of money to change gears, a few more dollars becomes irrelevant.
In addition, after having the 4.10's in for all last summer in Ohio, it makes the transmission so much more usable, all six gears. Can't wait to get on the road this year.
Old 03-29-2019, 02:20 PM
  #160
548chevelle
548chevelle's Avatar
Just ordered my 3.90's. I've done a few regulars rears- Ford 9", Dana 60, Chevy 12 bolt - but this one looks really daunting. I'd like to see a vid on doing it. Anybody know of one?
Quick Reply: [Z06] Motive 3.90 and 4.11 Gears IN-STOCK
