Are you my decks clean enough for head install
As the title states do you think they are clean enough? I spent about 3.5 hours today cleaning the decks and the bolt holes. I made a thread chase from old bolts and took my time. They look good but will check again before the heads go on. As far as the decks I very carefully used a razor blade to remove gasket material then sprayed a li t free town with brake cleaner and wiped it down. I plan to wipe again with alcohol like the DIY says when I actually install. The heads are due to arrive in a day or so and I want to be ready.
Thanks! Brent
Thanks! Brent
I used a product called "Goof Off", it's a high strength adhesive remover, to give the surface a clean up pass before I put it back together. I guess you could also use some paint thinner as well.
This is not something you can give a pass or fail to by looking at a picture. I double check my own work with the blind "feel" test. Wipe it off with a cloth and then with slight pressure and your eyes closed, glide your bare hand over the mating surface. If you feel something, you missed something. Trust your hands. I found a lump in a breast that the Dr. missed
Those decks look great. I also carefully used razor blades to remove old residue. I think you're good to go and did things right. Vacuum out your bolt holes if you haven't already. A hollowed out pen taped to a shop vac works well.
I used a shop vac in conjunction with air, as I hit it with air the shop vac caught anything that was blown out, but you have to keep that vac tube close and on top of bolt hole.
